Question about Garden
My wiper sniper pull cord is broken, how do u change the pull cord?
    Novelist:
  • 144 Answers
Hi vanzedo, I will try to help you out. Because you don't specify the brand and model I will try to give you the Weed Eater brand that is manufactured by Poulan because it is the best known in my area and I hope it is well known in your area, but it is pretty well the same procedure for other brands.
To disassemble starter, detach starter housing from engine. Remove rope handle and allow rope to wind into starter. Unscrew pulley retainer or pulley retainer screw and remove rope pulley. Wear appropriate safety eye wear and gloves before detaching rewind spring from housing as spring may uncoil uncontrolled. Try to prevent spring from unwinding if possible, I use a flat piece of metal stiff enough not to bend, about 1" wide or less and try to put it between the spring and pulley, if I have the room to do it and prevent spring from uncoiling as it is quite a job to put it back in. (good luck with that one).
To assemble starter, lubricate center post of housing and spring side with light grease. Install rewind spring so coil windings are counterclockwise from outer end. Install proper size and length of rope. Assemble starter while passing rope through housing rope outlet and attach rope handle to rope. To place tension on starter rope, pull rope out of housing. Engage rope in notch on pulley and turn pulley counterclockwise to place tension on rewind spring. Hold pulley and disengage rope from pulley notch. Release pulley and allow rope to wind on pulley. Check starter operation. Rope handle should be held against housing by spring tension, but it must be possible to rotate pulley at least an additional 1/4 turn when rope is pulled out fully.
I hope this is helpful to you even if a little bit. Regards and good luck. Denis.
Posted on Apr 02, 2011
I have a 2002 chevy impala,drivers side windshield works great,the passenger side doesn't work at all,help!
You mean wiper arm ? Probably broken wiper arm linkage bushing you can't see , under the cowling . Can you move the passenger wiper arm up an down without much effort ? An not the drivers side ? To see it or get at it you would need to pull wiper arms off an take cowling off to get at it . How To Install Replace Wiper Motor 2000 05 Chevy Monte Carlo Impala How To Fix Broken Wipers EricTheCarGuy
Feb 12, 2017 | Cars & Trucks
Under sniper fire
Stay low and under cover. Put something out for the sniper to shoot at and at the same time, get an oppo to look for the flash from at least 30 feet away. Call in air support or a mortar team.
Unless you are on the other side, in which case pull the pin on a grenade, count to 20 and throw it. :>)
May 06, 2016 | Watches
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
www.youtube.com/watch?v=G02OobT7fII
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
I have tried to post my question several times, asking how to change the pull cord on my Poulan 625 series lawn mower, it hasn't posted and I can't seem to get an answer.
did this break at the pull handle? if so you will still be able to re-use the same cord.
you have to first remove the pull mechanizum from the top of the engine. turn it upside down and get the old pull chord off 'If it has broken at the engine end of the cord. You will find the end of the cord inside, remove it with a pair of pin nosed pliers.
If broken at the pull handle remove the broken and of the cord from the back side of the handle. There will be a knot tied in either end. Assuming you still have enough pull cord . Cut the broken end so it is not frayed slip it through the pull handle and tie a simple knot & make it tight with some pliers.
re wind the spring by hand winding the cord back into the spool.
now you need a small zap strap to hold it all in place until you reinstall the pull mechanizum on top of the engine.Once you have done this cut the zap strap off and retrieve it as you do.
Hint* "with only 2 hands" I have used pin nosed vice grips to hold back the spring while I tie it off with zap strap or stiff string.
If the cord if broken at the engine end you will need to line up the cord input with the cord journal and hold in place while you try to feed the cord back through. Hint* use a smaller peice of wire to feed through the opposite direction and wind it around the cord several times so you can pull it through to the inside of the pull mechanizum and tie a knot. Good luck
Oct 12, 2013 | Garden
What fuel to use in stihl fs35 wiper sniper
Hi, unleaded fuel mixed at 50 to 1 with stihl two stroke oil. Regards Phil.
Jul 12, 2011 | Garden
How do you take off broken wiper arm on 84 buick skylark
you'll need to flip the wiper arm back towards you until it locks in the upward position. look for a small shiny pull tab at base of the arm. pull that tab outwards while prying up on wiper arm. it should come off with light pressure. this pulls the whole wiper arm off. hope this helps you!!
Aug 23, 2010 | 1984 Buick Skylark
Windshield wiper switch is broken, can't turn off wipers.
sorry sir no other way you hav 2 change the wiper switch in a authorised servic station
Aug 24, 2009 | 1991 Buick Century
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Windshield wiper motor
wipers generally only have one motor, with an arm that runs from one wiper to the other, basically making one a slave to the other. that is how they go at the exact same speed. I doubt it is the motor, moe likely it has dropped/broken the link arm.
Jun 21, 2008 | 1999 Ford Taurus
Garden Logo
273 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
