Question about Bosch HBN 442 / HBN446 Electric Single Oven
I interuppted power to bosch oven hbn 7305.0b in self clean mode now it is locked with errror 15 even now cool
5 Suggested Answers
SOURCE: Bosch HBN 455 Oven Cooling-Fan Issue
Our HBN655 had similar issues- the upper cooling fan would cycle on and off on a relatively quick duty cycle until the whole mess cooled off enough and it shut off.
My workaround is to turn the temperature dial off but leave the oven function dial on to BAKE. This seems to force the fan to stay on; then we shut it off a while later and avoid the annoying fan cycling.
(note- 2 years ago, our fan became intermittent, varying speed, etc... for about 2 months before it quit entirely. When that happened, the oven started to heat then the thermal cutout kicked in and the oven shut down entirely. We ended up replacing the fan and that fixed the bug... except now it's starting to act up again...)
(also note- the racks on this beast have a faulty design. if you have a heavy casserole and slide the rack out all the way, it tends push the sidewalls apart and the rack drops. I spoke with Bosch about this and they sent me new racks, no charge... so they know there's a problem. But the new racks don't fix the bug; they just make it harder to reproduce. I have actually had one rack fall with 2 piping hot casseroles on it. Fortunately no one was hurt.)
Posted on Nov 04, 2007
Master_Tech
  • 770 Answers
SOURCE: Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Posted on Jan 27, 2008
  • 27 Answers
SOURCE: INSTRUCTION MANUAL
you can obtain the instruction manual for this directly from the bosch web site free of charge if it is not listed there try the BSH Home appliances ltd site they are the manufacturers repair service in the UK
Posted on Mar 09, 2009
SOURCE: My Bosch HBN 5605 .0B oven has a 15-20 degree
I detected a similar problem following the sudden appearance of Err1 in the display. (Oven 4-5 years old, and the grill element failed when it was 3-4 years old). This indicated a temperature sensor problem. My local dealer came with his Thermocouple and confirmed an "under temperature" reading on the standard and baking settings. I agree that the fan setting is probably OK. He replaced the sensor. I monitored the situation for a while and was not happy because an under temperature could be quite dangerous when cooking certain foods, and also causes problems when baking bread.
The location of the oven sensor is also a problem because it is at the top right by the grill which also serves as the top heat source.
I had corresponded with Bosch about this and their response was, frankly, less than satisfactory. In the end I decided to call out their engineer (cost £85-ish) who wired my oven up to his computer. In the end he said that the oven was working as it should be (despite it taking a very long time to actually reach the target temperature of 200C.
In my view of I want 200C, then I should get 200C, not an approximation.
Interestingly the secret info (not in the manual) is that the temperature bar readout does not indicate that it has reached the actual temperature, but may be 90% of the temperature (so if you want 200C you get 180C.
An unsatisfactory solution is to get an oven temperature of the meat probe type and put that in the oven, then you will get a more accurate reading of the temperature. You would need one that goes above 200C (my first one only goes to 200 but I have found another that goes to 250C). Mine is by CDN model DTP482, any good cook shop should stock this.
Andrew Finch
Posted on May 05, 2010
Why wont fan turn off after use in oven bosch model hbn 13n5,1b
It should turn off after a while. The fan is actually the cooling of the case, it runs longer if I have used a higher temp setting. If it does not stop after app. 20 min something is broken.
Sep 03, 2014 | Bosch Ovens
Self cleaning
Set back on self clean, then after about a minute, switch off. The lock should disengage.
Apr 25, 2013 | Bosch HBN 442 / HBN446 Electric Single...
Oven cuts out as soon as it reaches temperature
not expert on bosch but sounds like cooling fan not working, either fan defective or cut in themostat not working.
Jul 22, 2010 | Bosch Ovens
I have a Bosch HBN 455 double oven with the convection oven on top, and a regular oven on bottom. The unit is about 5 yrs old. We recently ran the Self Clean mode, and it seems like it has malfunctioned...
Do you see any Error Message on the Display?
If not, then it should not be a Concern. More often this could be Thermal Fuse on the Back of the Unit ( On Most Models ) will stop the Broil and Bake from Turning ON. You would just start a bake cycle and the temperature will sit at 100 and something degrees and never raise.appliance.
Let me know, once you check the same.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 28, 2009 | Bosch HBN 455 Stainless Steel Electric...
Easy off ate all enamel off interior of oven
First off i must say that in your owners manuel it clearly states to not use any cleaning products inside the oven..
Second if the cleaner is now completely cleaned off then when put into the bake cycle it could possibly turn the cleaner into a toxic gas. I would not use the oven i would replace it.
Third having the enamel chip off is not a safety concern. it is merely cosmetic. however refer back to number 2.
Feb 13, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Jun 02, 2008 | Frigidaire Ovens
Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
May 28, 2008 | Ovens
Jan 20, 2008 | Bosch HBN 452 / HBN 456 Electric Double...
Bosch HBN 442 / HBN446 Electric Single Oven Logo
89 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
