Question about Car Audio & Video
I have an old Uniden car alarm in my 1980 TR7.The alarm is powered up but only sounds for a couple of seconds when activated.Ithink it could be a lose conection,I need a wireing diagram so I can trace the falt.On the back of the remote it reeds N32"VS" series.
dj_ricko_198
  • 128 Answers
SOURCE: 2006 PT Cruiser alarm sounds without
now sometimes this happens to let you know that one of the doors are open
check your doors
this is the only thing i can think of altho you have most likely checked it lol
also lock the car with the key
you don't want it to get stolen
Posted on Dec 29, 2008
SOURCE: starter wire diagram 1980 l48 corvette
dear friend:please go onto the following sites in order to find the diagrams .www.schiffeuropean.com, www.hmaservice.com and www.books4cars.com
Posted on Sep 23, 2009
  • 14036 Answers
SOURCE: no power to the fuel pump on a 1990 K5
CHECK FUSE + RELAY TO FUEL PUMP.IF THEY CHECK OUT GOOD.YOU HAVE PCM PROBLEMS. MAKE SURE PCM FUSE IS GOOD.YOU CAN BUY A HAYNES REPAIR MANUAL.IT HAS ALL OF YOUR ELECTRICAL DIAGRAMS.
Posted on Nov 11, 2009
johnjohn2
  • 5763 Answers
SOURCE: need a diagram for wiring trying to trace wiring
Posted on Oct 04, 2010
  • 10865 Answers
SOURCE: 1997 Chevy Silverado Car Alarm w/remote Start
Hello m1..... Here is the link to this alarm manufacturer including manuals, etc. If this site does not answer all of your questions, click on their contact icon and speak directly with their technicians. http://www.xlsperformance.com/cars_alarm_starter.htm
Joe
Thanks for choosing Fixya!
Posted on Dec 24, 2010
Where is the number one cylinder on a 1980 triumph tr7 2.0 engine
Next to the number two cylinder. Just kidding by yourself an owners manual from leather up.com the $35
Feb 23, 2015 | Triumph Motorcycles
How to ARM and Disarm a self contained ALARM system
An alarm that only sounds for a couple or three minutes, easily defeatable by way of crowbar on plastic? come on.
Nov 30, 2014 | Cars & Trucks
There is no picture when i insert a dvd. even after i used pac-tr7
broken screen or connection to the screen from opening too much, or, the dvd menu wasnt activated, but, it should automatically turn on when dvd is inserted. Bad dvd or really scratched dvds may not allow it to turn on.
Nov 18, 2014 | Alpine IVA-D106 Car DVD Player
Where is the 1980 triumph tr7 turn signal flasher located?
Front seating area, passenger side, under dash, mounted behind glove compartment
Application:
Hazard flasher .
signal flasher is located under dash drivers side left of steering collum , I gave you both just incase you ever need it .
Oct 13, 2014 | Cars & Trucks
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
Mercury Mountaineer car alarm sounds for no reason
Try using the doorkey after the door has been closed as if you did not have power locks. But most of the time, its automatic with the antitheft.
A shorting battery can activate the antitheft system. Have the battery tested.
Feb 04, 2014 | Mercury Mountaineer Cars & Trucks
1980 tr7 duel strongberg carbs. clean gas, pump works, rebuilt carbs. will not start! will run untill starting fluid burns -off.
Adjust the nut under the main jet needle to give it fuel to run with. The throttle control pushes the needles in too far and block of the jet so you have to give the jets a chance to allow fuel in
Oct 12, 2013 | Cars & Trucks
How do you turn off the HWS alarm on a makita bmr100
A beep tone will activate when selecting the HWS buzzer
alarm.
The alarm beep will become shoter and shoter every
15 seconds for one minute followed by one minute silence
before repeating the cycle.
The HWS alarm will sound for one hour until turning off by
pressing the Power button. Press the Power button whilst
the alarm is activated will cancel the alarm for 24 hours.
1. The HWS buzzer alarm can be set either radio is on or
off.
2. Press and release the HWS buzzer alarm button
, the symbol will flash.
3. During the symbol flashes, long pressing the
button for more than 2 seconds followed by a beep
and display Hour digit will flash.
4. Rotate Tuning Control to select required alarm hour,
then press time set button again. The minute
digit will then flash.
5. Rotate Tuning Control to select required alarm minute,
the press time set button again to complete HWS
buzzer alarm setting.
6. Press and hold down buzzer alarm button for
more than 2 seconds followed by a beep to switch on
or off the HWS buzzer alarm.
Display will appear when buzzer alarm has
been set.
May 25, 2011 | Car Audio & Video
check your doors
Dec 29, 2008 | 2006 Chrysler PT Cruiser
1997 venture keyless remote programming
SYSTEM OPERATION
System warning lamp located on top of the instrument panel
Press UNLOCK button once , turns on interior lamps and deactivates alarm (if fitted)
Press UNLOCK button twice w/in 5 seconds unlocks all doors, turns on interior lamp and deactivates alarm (if fitted)
To activate alarm system (if fitted):
Switch ignition OFF
Open driver's door
Press Lock button on remote
Close Driver door
warning lamp will flash when system is activated
Press remote power sliding door button will open sliding door (if fitted) only if unlocked first
Pressing remote panic button:
*Sounds horn intermittently
*Flashes exterior lamps
*Turns on interior lamps
**Pressing panic for the second time OR switching ignition ON deactivates alarm.
PROGRAMMING
Remobe key from ignition switch
Remove the "BCM PRGRM" fuse, from the fuse box
Close all doors
Turn ignition switch to the ACC position
With in 1 SECOND , turn the ignition switch to OFF then back to 'ACC'
(really, with in one second)
Open and close the driver's door. A chime will sound, indicating programming mode activated
Press and HOLD LOCK and UNLOCK SIMULTANEOUSLY untill a chime sounds 2 times ( about 15 seconds)
Repeat this exact procedure for all remotes to be programmed
Remove key from ignition
Refit 'BCM PRGRM' fuse.
4 REMOTES MAXIMUM CAN BE PROGRAMMED
Aug 24, 2008 | 2000 Chevrolet Venture
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
