Have new Optoma HD67 DLP projector for operation on an oil rig. Unit arrived with no instruction manual, require info on how to access lamp when replacement required also what is lamp part number ? Does unit have an Optoma ceiling mount assembly ? we have an Optoma universal ceiling mount but retaining screws are not compatible with projector thread sizes. Unit was supplied by Maplin Electronics Ken.
  • 563 Answers
SOURCE: dell 2200mp mounting screw
Hi wspy
If the look right next to the holes there should be a screw size written on the casing itself.
Posted on Apr 30, 2008
  • 1689 Answers
SOURCE: wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Posted on Jun 28, 2008
  • 979 Answers
SOURCE: olevia 232-s13 32"
Best bet is to go the wall-mount MFGR website and check out their instructions...accordianman
Posted on Jul 01, 2008
SOURCE: Bulb or Lamp Unit Timer
"paison" was correct and his solution did work for me. Make sure you first select TV on your remote. Now hold down the dvd/vcr button at the bottom of your remote while also holding down the "volume down" button on th front of the TV. Hold until a "Blue Reset Menu" appears on the screen and say the timer has been reset. Noe just follow the on screen instructions.
Posted on Feb 05, 2009
  • 4889 Answers
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Posted on Mar 01, 2009
Lamp fault
Look at the ballast module. It controls the lamp operation.
Dec 05, 2013 | Optoma GT750-XL - DLP projector - 3D...
Optoma ep 1690, the on/standby led is flashing green but when I try to turn it on the temp and lamp led's flash twice and nothing happens, the on/standby continues to flash green.
The projector lamp life may have exceeded its safe limit, check your instruction manual, sometimes you have to hold the on or off button for 10 seconds to reset this. All manufacturers are different but that may be the problem.
Here is a copy of the manual, I havn't read it, my solution is from experience of other projectors.
Good luck
Aug 04, 2011 | Optoma EP1690 DLP Projector
I have a Optoma projector HD70 How do you reset the lamp operating time?
Do the following for reset the lamp hour.
1. Press the menu button
2. Select Options.
3. Select lamp settings
4. Select lamp reset.
5 Select Yes
Jul 08, 2011 | Optoma HD70 DLP Projector
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- ------------ this is link for compatible cheaper lamp.Click this link:-- --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
HD70 DLP Projector: after replacing bulb warning message of "replaceme...
You need to reset the light counter. Access through right most menu item. Then arrow down to lamp settings.
May 17, 2010 | Optoma HD70 DLP Projector
The optics are dusty in an Optoma HD32 projector, I require a service manual which would indicated the correct method to remove, clean and reinstall the optics.
go to . He has excellent instructions for dismantling an optoma projector. However I took it one step further. I still had a problem with overheating due to dust after I followed his steps twice. Then I also removed the back of the projector which gave me much better access to an internal fan. I could see a substancial amount of dust coming out when I blew compressed air through it this third time around. It has been working fine for 6 months since.
Jan 25, 2010 | Optoma HD70 DLP Projector
How do you install a new bulb in the Optoma HD70 projector. Got a new bulb but no instructions
unscrew the screw on the lamp door, unscrew the lamp screws, pull the lamp out, replace with new lamp (making sure it's securely plugged in), screw it in, replace the door, plug the projector in, turn it on, enjoy!
Nov 07, 2009 | Optoma HD70 DLP Projector
Optoma ep 706, lamp lights on,replaced lamp, still not working
This is an unfortunate incidence and i will send you the serviceable manual of your projector if you can send me your contact email address to my email.Yes ,there are instruction to follow to replace lamps in projector if not you might miss it. First you must confirm that the lamp is OK from the vendors you purchase before anything.
Aniekeme Anthony.
Jan 21, 2009 | Optoma EP706 DLP Projector
I have no instruction manual supplied
The user manual is a CD-ROM and I was unable to locate it for download. However, try to contact them with the info below. Maybe you could purchase the CD-ROM, or they could email it to you.
Optoma USA
715 Sycamore Drive
Milpitas, CA 95035
Phone: (408) 383-3700
Sep 02, 2008 | Optoma EP709 DLP Projector
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
