Question about Numark DJ/iO Sound Card
I have just purchased Numarks' DJIO soundcard, and hooked it up to my Behringer VMX200 mixer, I am running Windows 7 and the driver has been downloaded from the Numark website. I have done all the necessary configs in VirtualDJ but I am still getting a muffled horrid sound through my speakers (Mackie Thumps) There is some sound....although awful, almost as if the speakers are only receiving a partial signal. Any advice would be greatly appreciated.
3 Suggested Answers
SOURCE: cant hear anything out of my speakers connected to djio
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
Posted on Jun 06, 2010
SOURCE: I cant get the djio to play through my mixer
i have the same problem. My wild guess is incompatible dj software and numark drivers. i am using vdj pro 7 but i tried to downgrade to 5.02. and use single output ---------- headphones -------------- two cards, and assigned them to numark usb audio device, and the sounds goes thru my mixer. but when i use the vdj version 7 or higher cannot produce a quality sound. it got some noise coming out.
Posted on May 20, 2011
The cd with behringer for w xp i wanna install cd for w7
You can download suitable drivers from Behringer's site. Are you using the 32- or 64-bit version of Windows 7?
BEHRINGER Control Downloads
Once you've done that:
  • Uninstall the existing Xenyx drivers.
  • Unplug all USB devices except mouse and keyboard and then in Device Manager delete all your USB hubs.
  • Reboot. Let Windows find and install the USB hubs.
Install the drivers you downloaded from the Behringer website.
  • Plug in your Xenyx. Windows 7 will install the drivers and you should have a signal.
  • Make sure you select the unit is input and output default in control panel.
Mar 15, 2013 | Behringer XENYX X1204USB 12-Channel Mixer
Channel 2 has gone quiet and is not working properly
Do you have the mode switch on split of stereo? The mix knob at 12:00?
Mar 13, 2013 | Behringer Vmx200 DJ Mixer 2 Channels with...
Apr 11, 2011 | Numark DJ/iO Sound Card
How do I hook my preamp up to my computer?
Either through your computer's soundcard (1/8" mic input) or you'll have to get an interface such a an M-Audio FastTrack. There has to be something that converts the analog sound from the mixer to digital info that you're computer can utilize.
Jan 13, 2011 | Behringer Xenyx 502 Audio Live Music Mixer...
Behringer Vmx200 DJ Mixer ...does it have a fuse?...... I AM HAVING PROBLEMS WITH MY SOUND.....
Yes, it has a fuse, however, if anything lights up or works the fuse is OK. Most problems are with cables or improper configuration of the unit and associated equipment regarding types of cables and grounding. Read you manual regarding cabling.
All your equipment should be fed from teh same receptacle. Powering devices from opposite ends of the room outlets is a sure way to have problems.
Oct 10, 2010 | Behringer Vmx200 DJ Mixer 2 Channels with...
Cant hear anything out of my speakers connected to djio
Apr 26, 2010 | Numark DJ/iO Sound Card
Mixer doesnt send sound to my computer
If you are using recording software you will have to look for Preferences and make sure that the software is detecting your soundcard. You also have to make sure that your PlayControl settings match the input on your soundcard to the ones your mixer are plugged into. You also have to match the RecordingControl which is under Options and then Properties. That is all under Sounds and Audio Devices in your Control Panel under the Volume tab then Advanced. If you have latency problems which makes the sound delayed from the input on your mixer to what you hear from your computer try downloading Asio4all although your mixer should have come with a disk with the proper drivers. If it didn't Behringer has a great support section at their site that has downloads for everything.
Aug 07, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
I want to hook My pc up to my mixer and play my karaoke files on there i have 5000 files on my pc i would like to use it like a karaoke player can you help? I have a Behringer UB1002 mixer and a Dell...
The question is, do you have the driver for your Behringer? the Music should be navigate from your computer Not from your mixer. If so, try to install the driver for your behringer and configure you library with designated software from your behringer. GoodLuck!
Jun 17, 2009 | Computers & Internet
Hook EQ to my mixer
I assume you want to put the EQ on the mains output of the mixer -- is that correct?
Just run the left/right out from the mixer to the left/right in on the EQ, then run the left/right out on the EQ to your amp.
May 27, 2009 | Behringer ULTRAGRAPH PRO FBQ3102 Turntable
Numark DJ/iO Sound Card Logo
44 people viewed this question
Top Numark Computers & Internet Experts
Mike
Martyn01202
Martyn01202
Are you a Numark Computer and Internet Expert? Answer questions, earn points and help others
