Wen turn laptop on the screen is blank n it just beeps
    Scholar:
  • 93 Answers
With out knowing the type of laptop or what bios its running or how many beeps and what the beep sequence is it is hard to give you a definite answer.Sometimes this can be caused by a faulty ram module or if the module has become loose--try undoing the cover where the ram (memory) is located and see if it is plugged in properly try carefully taking it out and reseating it on the motherboard.Make sure the computer is disconnected at the power and the battery is removed and only hold the ram by the plastic do not touch the metal parts with your fingers also try not to be standing on carpet .
I hope this helps
Andrew A
Posted on Apr 02, 2011
My asus laptop has no screen display and can sense flash disks
First you thing to check is when you turn the laptop on it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max. If it dose beep then take a normal PC monitor and connect it to your laptop and see if that works. if it dose work then it means that the screen is busted or you should pess the screen buton on the keyboard
Nov 02, 2013 | ASUS Eee PC 1000H Laptop
I have dell power edge 1900, it can not display even though the power turns on well
you must take note to the beep of your laptop. when you turn the laptop on it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max. if it dose make the beep then try to connect a normal screen to the laptop.
Oct 26, 2013 | Computers & Internet
My laptop shows black screen when wished on ...what do I do ..help me
Oct 25, 2013 | Computers & Internet
My gateway laptop nv series screen wont turn on when i boot up my laptop
you must take note to the beep of you laptop. when you turn the laptop op it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reapplied every 3-6 mouths max.
Oct 24, 2013 | Gateway Computers & Internet
N148 plus notebook
you must take note to the beep of you laptop. when you turn the laptop op it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max.
Sep 17, 2013 | Samsung Computers & Internet
Oven was working great then it beeped and the display screen wen blank an the oven went off. Screen remains blank and now oven does not work
computerized? I think, if computerized, you should call for a repair person, and get an estimate. You can decide if it is worth the money to fix, or if you would rather go with a new one....weight your options!!
Good luck........also, check on line at:
www.howthingswork.com you can learn there too.
Aug 01, 2009 | Kenmore Ovens
My lenovo n200 does on turn on it beeps and screen remains blank
Hi, you must remove both memories and return to wear them in the socket, it is for it that your equipment not power on correctly
Jan 20, 2009 | Lenovo 3000 N200 Notebook
Laptop does a long beep, followed by two short beeps.
One long followed by two short beep IS a video error. However, your model laptop does not have a separate video card. The only fix is to replace the mother board. Here is the service manual that will show you how to take apart the laptop and even give you the part number you would need to replace the motherboard.
Thanks and please take a moment to rate as fixya.
Dec 07, 2008 | Computers & Internet
When i turn on my laptop, the screen is blank
It seems to be u have problem with ur RAM ..Try to change it
Nov 29, 2008 | IBM ThinkPad R40 2722 Notebook
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
