Question about Fender Audio Players & Recorders
I need a new power amp pcb board for bassman 200 but cant find a serial number for the ordering
    Genius:
  • 1,175 Answers
Check the back panel or underneath
Posted on Apr 05, 2011
HDMI ports won't work
you will need the MAIN PCB & can find your part number at the following web site, you will need your complete model/serial number to isolate the right board for your TV.
http://www.shopjimmy.com/tvs/tv-main-boards?tv_brands_select=Lg&tv_models=Lg+32LG30-UD
Mar 10, 2015 | LG 32LG30 32 in. LCD HDTV
Standby led but cant on power
Look like malfunction AMP PCB Board.Please open top cover, unplug flex cable attached to connector AMP PCB. Try now power- ON the unit.
Jul 24, 2014 | Panasonic Home Theater System System
Our shredder is a Kobra 240 ss5. It will turn backward but not forward. The circuit board has a burn on it. Can I order a new circuit board for it?
By now you mave resolved your prob however.... yes you can order replacement PCB's.
The part # is 27.045
Before you just replace the "blown" pcb you should also check the motor; or, when you install the new pcb you will just blow the new pcb also.( if the motor is faulty.)
To check the motor you will need a multi meter.
There are 3 wires...black, red & blue wires. Using black as the common wire measure black to red..this should be approx 6 ohms, the same when you measure black to blue. Between blue and red you should get about 12 ohms. If you get a short on any of these readings then the motor will have to be replaced BEFORE YOU REPLACE THE PCB.
You don't say what country you are in..these readings and the part number are good for the USA &Canada.
The part # will be different if you have the 240 ss5 E/S model.( has a blue light on the panel.)
Hope this helps.
Apr 05, 2011 | Elcoman 240 SS5 Shredder
Copier model canon ir 3300 error 000354-0002
E354 is a mismatch or absence of the serial number stored in the Serial Number PCB and Main Controller/Image Processor PCB or Counter PCB. Check and reseat connections to the counter and Serial number boards on the main controller.
Jan 10, 2011 | Kitchen Ranges
Error code 354-0002 ir7200 serial number pcb
when you changed the main controller for the copier did you use the counter board that was on the old main controller or did you put the counter board from the old one on the new one.... if you don't use the old counter board with the new main controller then that problem will occure
May 19, 2010 | Canon imageRUNNER 7200 Copier
Canon ir2020-seystm err e354 please tel me what ido tanvir gillani
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory.are you trying to change the counter board this not possible bec the serial no of the machine is embedded on the counter board so no counter tampering allowed
Oct 01, 2009 | Canon imageCLASS D320 Digital Copier
Amp powers up but just hums
The output transistors are probably shorted. There should not be any DC voltage going to the speakers. DO NOT run it this way for long or you will damage the voice coils of the speakers. This unit needs service. Expect a parts cost in the $25-$40 range.
Dan
Jul 25, 2009 | Audio Players & Recorders
Error 354
E354
controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
Jul 15, 2009 | Canon Office Equipment & Supplies
132 people viewed this question
Top Fender Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rick Moore
Rick Moore
Are you a Fender Audio Player and Recorder Expert? Answer questions, earn points and help others
