When connecting my external hard disk bufflo hd ce640u2, the operating system windowsXp says the the hard needs to be formatted but when I connect it to Linux (fedora 8) the operating system can see one folder stored on the hard. please, how can I retrive the stored folders on my hard drive
  • 27,725 Answers
You could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
or During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
you could do either of these thigs first
hope this helps
Posted on Apr 02, 2011
How to reformat external drive for mac
Connect the external hard drive to your mac
Open utilities folder from applications
click on disk utility
Highlight the hard disk you want to format. Careful not to choose Macintosh HD
Click Erase on the top
Select the format Macintosh OS Extended Journaled
Click OK. This will make your hard disk formatted to Mac OS
good luck
Sep 24, 2011 | Computers & Internet
My 500 GB store jet Transcend USB hard drive not detected. when sometime its detect, message is flowing " Hard disk is not formatted. do you want format now? " please help me what i do ?
You will need to format the disk so the file structure can be read by your operating system. Formating the disk will wipe all data from the disk but will only need to be done once.
Mar 01, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I am using Transcend 320 GB external hard disk in a Windows 7 Operating system. It is keep on asking me to format the disk while i plugging in to laptop. Unable to see the contents in the external hard...
guess you are using a USB port to for that.....
1 - check the cable that connects the HD to the USB port...change the cable and verify
2 - connect to another PC and check if it's ok there
3 - bring another ext HD from a friend and try conencting that....check if that's OK
4 - there could be a corruption in the HD that is preventing the PC from reading it
cardinal rule for USB....not a very dependent device specialy if connecting thru USB data cables....
solution
always use a good qty USB data cable compatible with USB2....as some cheap cables are only for USB1
visit my website
www.sureshayyar.110mb.com
for more info on PC issue and solutions...
reg
Kris
Feb 17, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I have a Maxtor 3100 100gb external HD and tried to backup my computer and it would only backup 4gb. I got a message that if the HD is formatted in FAT32 it would only backup 4gb. I need to backup about...
1. Please connect you external HD to your computer
2. Fat32 can only handle a limited amount of data
3.Go to the Control Panel
4. Open up Administrative Management
5. Open Computer Management
6. Open Disk Management
7. In the denter panel you will see your Maxtor expressed
8. Right click on the drive
9. Click format
10. Choose NTFS
if not given the coice, it will usually format to NTFS anyway, but get smart, explore Disk Management and make sure
11. I'm giving a general scenario across 3 different Windows OS Sytems
12. When you tell us your exact Operating System, we can be more helpful
TheSelkie
Oct 04, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Format fat32 in vista for external hard drive
Click on Start > All programs > Accessories > right click on cmd. Select run as Administrator. Open it and connect your external hard disk. Then give the following command: Type format f: /fs:fat32 /q. In this the f is the drive letter of your external hard disk. The windows utility will format the disk and convert it to a FAT32 partition type.
Oct 15, 2009 | Microsoft Windows Vista Home Premium with...
Maxtor disk install
for an exteral disk you shouldnt need a new operating system. infact You dont. Usually new disks are not formatted. Try connecting it and formatting it to the correct file system. You may need to try to format it using a windows based PC also as im not sure how to do it under MAC os's
Sep 11, 2009 | Computers & Internet
How can i install and format a hard drive
Install the HD into your computer case with screws, connect a ribbon cable and a power cable, ensure that your HD is set to master or slave, depending on where it is installed in your drive chain (IE: only, or first, device should be master, second device should be slave). Startup the computer. Windows should recognize it, but if it doesn't, Under WindowsXP and above, goto control panels, open administrative tools, open Computer Management, Select Disk Management, find the new disk in the lower portion, right click on it, and create a new partition.
Hope this helps!
-Backu
Jan 16, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
