Question about Shimano Xtr Mountain Bike Dual Control Brake/Shift Levers
The cable to the rear wheel gear selector has snapped , I need to know how to free the cable end from the handle bar twist grip
    Brigadier General:
  • 8,546 Answers
What must i strp inside my kia rio 1.4 2013 to change my gear shift cable that snapped
Dimanche T bar shifter and console it should bolt to the end of T bar and unbolt at gear selector.
May 25, 2015 | 2013 Kia Rio
How do i replace grips on 2009 electra glide ultra classic
For twist grip equipped motorcycles to remove the throttle or right side grip remove the upper and lower switch housing screws, loosen the upper screw securing the handlebar clamp to the master cylinder housing. Remove the lower clamp screw with flat washer, separate the upper and lower switch housings and remove the throttle grip from the end of the handlebar. (To remove the throttle grip, a slight tug may be necessary to release index pins in grip from receptacle in seal cap of twist
grip sensor.)
With throttle cables, to remove the throttle or right side grip slide the rubber boot off of each cable adjuster, loosen the jam nut on each adjuster, turn the adjusters in the direction that will shorten the cable housings to their minimum lengths. THEN remove the two screws and separate the upper housing from the lower housing, unhook the ferrules and cables from the throttle control grip and the lower housing, (remove friction spring, throttle friction screw and spring from the lower housing only if necessary), (only if and as necessary mark the position of the master cylinder assembly forward position and split line on the handle bars) (to be safe squeeze the front brake lever and place a 5-32 inch thick cardboard insert between brake lever and lever bracket and then release brake lever to hold the lever in this place to protect the brake switch from damage if the switch housing and the master cylinder get separated) (and only if and as necessary, loosen the two perch screws) move the lower switch housing as necessary and remove the grip.
To install the throttle grip apply a light coating of graphite to the handlebar and the inside surface of the upper and lower housings, (if removed, install the spring, throttle friction screw and friction spring in the lower housing) (and, if removed, attach the cable assemblies to the lower housing), (throttle control cable has a 5-16 inch fitting end and is positioned to the front of the lower housing. and the idle control cable has a 1-4 inch fitting end and is positioned to rear of lower housing. Install the throttle control grip over the end of the right handlebar, position the lower housing onto the right handlebar, engaging the lower housing with the throttle control grip, position the ferrules over the cable ball ends, seat the ferrules (with the cables attached) into their respective notches of the throttle control grip, install the upper housing over the right side handlebar and secure it to the lower housing with the appropriate two screws and hand tighten them, then align the brake master cylinder and perch assembly with the marks made prior to loosening them, and beginning with top screw, tighten the two screws to 108-132 inch lbs using a T27 TORX drive head and then tighten the upper and lower housing screws to 35-45 inch lbs. THEN point the front wheel straight ahead and WITH THE ENGINE OFF, adjust the throttle and idle cables by turning the adjuster in the direction that will lengthen the cables. Gently twist the throttle control grip to the fully open throttle position (fully counterclockwise) and hold it in this position and turn the throttle control cable adjuster counterclockwise until the throttle cam on the induction module (or carb) contacts the throttle cam stop, release the throttle control grip and turn the adjuster counterclockwise an additional 1-2 to 1 turn and tighten the jam nut on the throttle control cable adjuster. THEN turn the handlebars fully to the right and turn the adjuster on the idle control cable counterclockwise to lengthen the sleeve until the end of the cable housing just touches the spring within the cable guide. NOW check the adjustment by, with the throttle friction screw loosened, twisting and releasing the throttle control grip two or three times. The induction module throttle wheel must return to the idle position each time the throttle grip is released. If the throttle does not return to idle, turn the idle adjuster, shortening the cable sleeve until the correct adjustment is obtained, tighten the jam nut and slide the rubber boots over each cable adjuster. NEXT start the engine and with it idling turn the handlebars through their full range of travel and if the engine speed changes at all during this maneuver, adjust the control cables according to the foregoing procedure so that there is no change in the idle speed when the handlebars are rotated through their entire range of travel.
To remove the clutch or left side grip remove the two screws and separate the upper housing from the lower housing. Mark the forward position and clutch perch split line on the handlebars and then as necessary loosen the two clutch perch screws and move it out of the way so that you can access the grip end. If you want to save the grip take a small screwdriver with about an eight inch length and insert it into the grip, wiggling it to loosen the glue somewhat and then spray some brake kleen into the space under the grip where the screwdriver blade is inserted and wiggle and twist the screwdriver around to loosen the rest of the grip glue and pull the grip off. Sand down the handle bar area where the grip will rest and apply grip cement to the area and slip the grip on. If the left hand grip is patterned, align it with the pattern on the right hand grip with the throttle in the fully closed position, immediately push the grip completely onto the end of handlebar using a twisting motion. Do not hesitate when installing the grip or the adhesive may dry before installation is complete. Allow 6 to 8 hours to elapse at 70 degrees F to allow the adhesive to fully cure. If a newer non-glue grip is being installed slip it on with the flats properly oriented to fit with the switch housing halves when they are installed. Install the switch housing halves and lightly tighten the two screws and then orient the clutch perch to the previously made alignment marks and beginning with the top screw, tighten the screws to 108 - 132 inch lbs using a T27 drive head and then tighten the switch housing screws to 35-45 inch lbs.
Sep 20, 2014 | Motorcycles
What's the best way to change handle grips on a 1972 honda ct90
assuming you have bought yourself a pair of rubber grips, with a sharp knife cut through the grip to remove it clean away any old glue, replenish glue onto grip and handle bar and simply push back on to handle bar quickly clean away any unwanted glue, remember to check you new grips for internal diamiter these will be different sizes, with smallest bore grip going on the left handlebar, and the larger on the throttle twist grip, if you have bought honda original parts then the twistgrip side may be a complete unit , in which case you would need to undo the 2 screws that hold the rhand switch gear together, and twist the grip in the opposit direction to what you would do when you ride it to remove it from the bendix throttle system, replace in opposite manner using a small amount of grease inside the metal sleve,
PE, UK
Oct 30, 2010 | 1972 Honda CB 100
I need to remove the rt.handlebar throttle grip and replace it. need some pictures.
If you want pictures, I'm afraid that you'll have to purchase a manual somewhere. This forum will only allow me to send a picture of 150Kb size. Replacing the throttle grips is not difficult.
First, loosen the locknuts on the throttle and idle cables at the twist grip. Adjust the adjuster barrel inwards all the way getting as much slack as possible. Now, loosen the bolts holding the front master cylinder onto the handlebars and slide it towards the center of the bars just a bit. Remove the two bolts that hold the right handlebar switch housing together. Carefully lift the top portion of the switch housing and move it towards the front of the bike exposing the throttle twist grip. Work each of the cables out of the nylon wheel of the twist grip. Do not loose the barrels that go on the ends of each cable. Once you have the cables loose from the wheel, lower the lower switch housing and remove the right grip from the handlebar.
Now, take the new grip and apply a coating of white lithium grease to the wheel part and the inside of the throttle sleeve in the grip. Put a coating of grease on the handlebar end where the sleeve rides as well. Slide the throttle sleeve and grip onto the handlebars. Bring the lower switch half up and reconnect the cables to the throttle wheel. Carefully reposition the top half to the switch housing and make sure that no wires are being pinched. Install the two bolts but don't tighten. Slide the throttle grip all the way up on the handlebars and then back off about a 1/4" or so. Tighten the two bolts. Now, adjust the two cables to where they each have just a bit of slack. Turn the throttle grip to the wide open position and release it. The throttle should snap shut. If not, work with it until you get it to where it does. Once operating properly, reposition the front brake master cylinder.
Make sure your throttle operates properly. An improperly operating throttle control can cause lose of control of the bike resulting in serious injury or death.
Good Luck
Steve
Sep 06, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
Cable snapped and I put in new cable but cant get the gear to ingage.
If, we're talking about your clutch cable, you need to regulate it, either by the bolts down to the gear box, or up at your left grip by the twisting distance screw.
The best way to do it right, is FIRST, spray down to your cable enough penetrating oil, that will help it slip easily. Locate the cable to the gear knee that comes out of the box, (there should be two bolts) and unscrew the one that's between the knee and the black protective of the cable, until the point that you pull your clutch grip, and you get a few mm, of "dead" motion and then gets tight. When you get that, tighten the bolts, and you're probable done. Remember, that the twisting distance screw at your grip, must be toghten, no space. Cause from there later you'll be adjusting the free space before pressing the clutch.
Quite easy. Should be done in no more that 5 min. Good luck
Aug 17, 2010 | kawasaki KX 450 F Motorcycles
1995 xjr400 throttle sticks open and will slowly close on its own if allowed. already loosened bar end and replaced grips but not any better. any ideas?
they can stick in a number of places.
You may need to dissassemble the hand throttle assembly
Make sure the plastic twist grip turns freely on the handle bar.
Check the new grip doesnt push against the throttle switch assembly.
Check the cables move freely
Check the cables dont have any frayed ends
check the cables arnt missing any of the plastic outer cover
check the cables a routed correctly and dont get jammed or pulled turning lock to lock
Aug 10, 2010 | 1998 Yamaha XJR 400
Shimano gears for a cycle... gear selecter not working at the r/handle bar end. I've dismantled it and trying to work out how the wire works and is set back in place as it is a twistgrip type.....
Check the rear dérailleur and the wire which protrudes. Its sounds like it has come loose and slipped, causing you not to get any gears. Follow the wire from the r/h twist grip, along the frame and towards the rear. If the wire has come out of its stoppers then refit.
If the wire is snapped inside, you should be able to see the cable move when you change gear. When you can't see the cable move, it will be snapped inside there. Are the exposed wires rusty? High possibility of a snapped wire.
I hope this helps, please vote for me if it does. Thanks.
Jun 17, 2010 | Cycling
I have an '86 Kawasaki ZL 600_A. I'm replacing the wiring harness for the run/off switch/starter button assembly, and I need to remove the throttle cables so the old assembly can come off. How do I get...
the best way is to lossen the adjuster nuts at the carbs and then at the throttle undo the switch gear remove the bar end pull the twist grip by pulling it off the bar with the swtich grear then remove the nipples from the twist grip then remove the cables from the switch gear then refit in reverse and adust the cables should have about 3 to 5 mm of freeplay hope this helps
Oct 29, 2009 | 1986 kawasaki ZL 900 A2 Eliminator
Need to adjust the front derailer, it won't change gears
There are two small screws which control the travel limits for derailer systems. Normally located top left of front mechanism when viewed from side. Adjust to allow travel within limits of gearing. Make sure that cable is not slack when in low gear position.
Jun 10, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Brake assembly
If you loosen the wire that is connected to the gripping machanism first , you will have long enough wire to put it throu the brake grip first then tighten it back at the wheel gripping area.
Dec 01, 2008 | Huffy Disney Princess 16 in. Girls Bicycle
Shimano Xtr Mountain Bike Dual Control Brake/Shift Levers  Logo
185 people viewed this question
Top Shimano Cycling Experts
John Egan
John Egan
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
