Question about Homelite Mighty Lite Lawn Trimmer
I purchased a model f2020 weed eater from bunnings naenae the line cartridge broke up and i went to get a replacement from bunnings they don't stock homelite parts but ordered one for me i have been waiting now for 6 weeks call i bunnings weekly never get a satisfactory answer nor do i get my part is there any other store in lower hutt i may purchase the part? cheers ty
    Novelist:
  • 111 Answers
You can order the part from www.homelite.com You will need your model number to help you select the right part. You will need to click on the order parts text in the upper right hand part of the screen. This will take you to another page which will ask you to go to the homelite parts catalog. After you click on the parts catalog link, it will ask you to agree to the terms of use for the website. READ THIS CAREFULLY.
After you have agreed to the terms of use it will take you to another page. From here you can input the model number of your unit. Input the f2020 into the search box and click on search. It will ask you which version of the model you have. On the right side of the screen it will have a parts breakdown. You should select (Shaft-Spool and String- Grass Deflector). This will pop up a diagram with a parts breakdown which will include part numbers to help make ordering the correct part easier. I believe the part that you wish to order is part number 17 of the diagram. When you click on the part number in the diagram it will select it below the diagram and will flash for a second. At this point it has an option to add this part to your shopping cart.
I hope this helps get you back in business.
Posted on Apr 05, 2011
Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
change the fuel lines over on the carby
you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
Mar 12, 2017 | Garden
John deere 260g weed eater how the line goes on keeps breaking
Does the line break or is it the head. If it is the line try using a thicker type of line, or a better brand. if the head is broken this may need to be replaced, but first check to see if you have it correctly assembled.
Aug 10, 2011 | Garden
Gas line with filter broke inside tank how to
get new line cut end at an angle , lube with oil and twist it in, snag the line and pull it out the filler hole and insert filter on the end, connect and enjoy.
May 28, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
On weedeater blower and vac gas line is broke from carb into tank does it just connect to fuel filter in tank model 1925
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
Jul 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Apr 04, 2009 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
254 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
