Question about Ricoh Aficio 2022 Black and White Copier
I had a functional problem sc 546 with my copier Ricoh 2022
  • 794 Answers
Hi mkpack,
The error code SC546 that you're getting with your Ricoh Aficio 2022is related to unstable fusing temperature. There are two possible causes for this issue. These are, the thermistor is already defective and/or the crusted toner on the fuser roller. To reset this error code (SC564) you might to follow these steps:
1. First, press the yellow clear all button.
2. Then, select 107.
3. Hold the red stop button until the machine switches to SP Mode.
4. Afterwards, press the copy SP or system SP button.
5. You have yo shut your machine off and then turn it back on.
If after doing these steps and still you're encountering the issue you might need to remove the fuser and clean it. Also, you miht need to replace the thermistors. It's the black aluminum roll in the fuser unit.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 02, 2011
Ricoh aficio SP4100NL error sc 546
Ricoh uses error codes in order to alert users that there is a problem with the functioning of the copier. Codes that begin with "SC" refer to issues with the fuser components, which heat up to bind the toner or ink to the paper. While clearing the code can be accomplished by most users, it is important to point out that clearing the code does not fix the problem. Codes that reappear should be addressed by a certified Ricoh technician.
Instructions
    • 1 Press the "Clear Modes" button. This button will be on the main panel.
    • 2 Press the "1,0,7" keys in succession. You do not have to hold the buttons down together but need to press and release them in this exact order
    • 3 Press and hold the "Stop" key. You will need to hold this button down until the Ricoh enters service mode. The touch screen display will say "service mode" and three soft keys will appear.
    • 4 Press the "Exit" button. This button will be on the touch screen display in the upper right hand corner. Once pressed, the copier will return to normal operation mode.
    • 5 Turn off the main power. The main power button will be located on the side or front of the copier.
    • 6 Turn the power back on. Once the copier is powered back up, the service code will be cleared.
Jul 20, 2014 | Ricoh AFICIO SP4100NL MONO-LASERPR 31PPM...
It appears codes SC 548, 541 and 546, and key tool machine does not function
are yo try to go to sp mode and reset if it not work out yo must change thermistor in fuser unit
Jan 11, 2011 | Ricoh Aficio 1035 Copier
Je possède un copieur Ricoh 1022 .il est en panne . il affiche SG 546 . Aussitôt j?affiche 107 en appuyant sur le bouton jaune pendant un moment .l?appareil se mit en marche pendant quelques...
SC 546: Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause: • Thermistor defective
• Power supply unit defective
Oct 20, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Functional problem sc546
sc 546 is a fusing related code. either the fusing lamp or the thermostat is blown out. one of them needs replacing
Oct 01, 2010 | Ricoh Aficio 150 Copier
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
Functioning problem with aficio 1033 or 2033,not sure, church cop
You must check the display for a code like SC-542 or something loke that.
Sep 17, 2009 | Ricoh Aficio 2022 Black and White Copier
Error code SC 546 in Ricoh 2045e
It's fusing unit but the thermistors connection can be good, but check do they are touching the surface of the hot roller and check do on the side where they are in touch with the surface of the hot roller has some attached toner on them.
Jul 01, 2009 | Ricoh Aficio 450 Copier
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh Aficio 2022 Black and White Copier Logo
1,193 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
