How do open the door on an asko 10504 washing machine
  • 1294 Answers
SOURCE: Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Posted on Jun 11, 2007
  • 49 Answers
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
  • 417 Answers
SOURCE: asko washing machine w6342 showing f3 and cant open door or operate?
Make sure the programme selector switch is at an end of wash position as these door locks are interlocked to prevent accidental opening during operation. There is also a 2-3 minute time delay after the was finishes so disconnect for say 5 minutes and try again.
If it still doesn't open you will need to get access to the mechanism dependent on what type of relrase mechanism you have;
if it is a push button release with a cable to the lock sometimes you can remove the top panel of the machine and pull on the cable or linkage to open.
If it is a lever type release mechanism this is more difficult to open but you can sometimes reach and release it by the same method.
Always disconnect the machine from the electricity supply before working on it.
Posted on Oct 13, 2008
Krazytech
  • 725 Answers
SOURCE: I have an asko wm200 washing machine. I have an F3
open the little door at the bottom or remove the toe panel... then there is a coin trap... that will let you remove the water there is a black hose with a plug on the end remove plug and drain the water...by turning it and pulling it you can remove the coin trap and you my be able to remove somthing stuck in it... also there is a red string you can pull it and release the door
Hope it helps if NOT let me know more about your problem... and I will help
Posted on Sep 26, 2009
SOURCE: My Asko 6461 washing machine - F3 code
F3 problem, I had the issue on model W6461, however, judging by the amount of F3 issues posted this could work on other ASKO models If the coin trap in the drain is clear of debris, try this. Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet in the wall or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear back through the coin trap.
7) Pour some water into the open end and blow this back through the drain as well.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water (all over the floor, don't forget the towels!)
Just ran the machine now and fault cleared.
Good luck
Jurgo
Posted on Sep 13, 2010
My Asko 10504 has started making what sounds like a metal on metal grinding sound when it spins. It's as if the whole drum assembly is moving more than it should and coming into contact with something,...
COULD BE THE TRANSMISSION SPRING OR TRANSMISSION BEARINGS. EVEN UR TUB BEARINGS IN THE TUB, A BAD MOTOR COUPLER HOWEVER U WOULD NOT GET ANY SPIN OR AGITATION IF THE COUPLER WAS BAD. BAD BREAKING SYSTEM WOULD NORMALLY MAKE NOISE BUT WHAT U WOULD GET THEN IS A COMBINED SPIN AND AGITATION DURING SPIN CYCLE,
Mar 23, 2015 | Asko Washing Machines
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
I have an asco 10504 washing machine. Very shortly after it starts the washing cycle it goes in to a fast spin. If I turn the power off and on a few times it eventually starts washing properly. This has...
Hi, Welcome to FixYa. Before I can accurately help diagnos the problem with your Asko 10504 I need to ask a few questions. Does the unit go directly into this spin with or without draining ? Does this occur regardless of cycle selection ? I will watch for your reply, please be patient if I don't respond immediately as we may be in different time zones as well as I am often working hands on repairs as I try to answer here at FixYa. Regards, Macmarkus :)
Sep 08, 2010 | Washing Machines
After a power serge caused by the local power authority we can not open the door to our ASKO W6021 - we have washing locked in the machine and want to take it out before the machine is taken away to be...
prise open the samll square door at the bottom left using the divider in the soap drawer. Once open extract the red loped handle and pull on it ot manually open the door.
Apr 03, 2009 | Asko W6021 Front Load Washer
Operation manual
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/10504-_E
I think this web site has a PDF of your manual. If not try to googe ASKO 10504 washer manual
good luck
Jan 30, 2009 | Asko W6021 Front Load Washer
Motor not running in Asko 10504 washing machine
The motor might have burned out. Another possibility would be a partially fried control board.
Jan 17, 2009 | Asko Washing Machines
Can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
Oct 16, 2008 | Asko W6021 Front Load Washer
Asko front load washing machine
Try some WD40 on the door mech,(on door, ie.) And with switch off, close & open door 4 or 5 times.
May 09, 2008 | Asko W6021 Front Load Washer
Asko 10505 - wash finished, door won't open
Mar 06, 2008 | Asko W6021 Front Load Washer
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
