I have plugged in the Parrot by Martin Szekely and I I get is the opening menu with four colored blocks and the website address. When I go to the back the navigation keys do not work (I have pressed lightly held down etc.) and also the stand by button also does not work. It seems like I may have a dud as I have no way to access the menu. Any top tips? Also, does it connect to a MAC? I have parellels but wanted to check Nancy
  • neferriman Apr 02, 2011
    Thanks, I put in the card and unresponsive...so much for the surprise bday gift - a frame preloaded with photos...cheers
    yes, but just told me what I thought. Fast job replying thanks
  • 11,800 Answers
This is a very simple digital frame that needs to connect to a pc or Mac (yes, it will work with one) via WiFi or Bluetooth. If you can't go into the menu to pair it then yes, you got a dud and you must replace it.
But you should try one last thing before returning it: put some pictures on an SD card, put the card in the frame and try to access the menu to display those - if even now it's unresponsive then you will know for sure.
Posted on Apr 02, 2011
  • Azrael SRL Apr 02, 2011
    In that case return it, it's indeed a dud - it happens.
No contacts in address book after pairing nokia C5 with Parrot CK3100. I find that my contacts are not available on the handsfree. I have used 2 other phones, with this same device, without a problem.
Your Parrot may need updating to work properly with a phone as new as the C5. but you can try the following,
To send a contact
* From the phone press MENU button and go to CONTACTS
* Select the contact you want to send and chose OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / MORE DEVICES
* The phone will search for the available devices
* From the list select the Parrot Product
To send several contacts:
* Select the contact you want to send and choose OPTIONS / MARK/UNMARK / MARK
* Repeat procedure for several contacts
* Open the OPTIONS menu and chose SEND BUSINESS CARD / VIA BLUETOOTH / MORE DEVICES
Oct 01, 2011 | Parrot Hands-Free Car Kit with LCD Display...
I can;t download my phonebook from my nokia 6120 to my parrot 3200
Check if the phonebook using is the phone from the memory of the phone and not the one of the simcard.
Cause only the directory of the phone will working.
Did you try to send the whole phone book via the object push, but you have to connect the phone via the specific menu settings -> pair with phone and then select without synchro.
You will have to rebuild the pairing to block the auto synchro and then send the phonebook via the object push.
Maybe the question could be in relation with the software version of the kit or the phone, then check the software version of the kit and just check the release note on the web site of Parrot to get an idea of the combination between your devices.
Dec 27, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
My nokia 2330 classic doesnt pair with my parrot 3200 ls color. after synchrinsing them unable to get authorisation code
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
HOW TO CHANGE THE LANGUAGE on parrot ck3100?
download update from parrot website, select the correct language on update software then update the parrot via bluetooth on computor/laptop
Jun 16, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
Need amanual & password for a md 85722 to link my phone
http://www.parrot.com/uk/support/onlinehelpguides/parrot3200ls-color
the pass code come when you make the research of simply when you use the menu settings -> pair with phone and activate one of the menu.
Mar 20, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Problem transferring contact list from BB 8330 to Parrot 3200 LS
I had the same issue with my Nokia phone a long time ago. To solve that issue I had to upgrade the Parrot's firmware with the laptop through bluetooth connection while in the car. I have done this a few times to get the most out of my parrot.
I recently got a Blackberry and had no issues with the contacts whatsoever. I do have to say that I dont have 500 contacts, but only 130.
If I were you I would try to update the Parrots firmware to the latest one available in the parrots website.
I am not sure if the parrots has a maximum contacts restriction. That might be also your problem.
Hope it helped.
Nov 26, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
PUTTING CONTACTS ONTO PARROT 3200
menu, contacts, mark all, send via bluetooth.
Sep 23, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
How to lock IE7 to one website for public use
To block any website from internet explorer follow these steps:
1- Open tools menu from the menu bar of IE.
2- Click on Internet Options.
3- Now click on Privacy option from Internet options menu bar.
4- Now click on "Sites"
5- There you will find the address bar. Write the URL of the site you want to block and click on "Block".
You can block as many sites you want to block.
Apr 24, 2009 | Microsoft Windows XP Home Edition
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
