Question about Hisense TL2620 26 in. LCD Television
I want to know hw to connet Laptop to TV . My TV model is 24K16P & Think pad laptop PLs advise I need to connet thru VGA or Component?? I have Chinese TV, unable to connect properly pls advsie ON priority
    Problem Solver:
  • 6 Answers
You should have an S video link, or use VGA (PC) input via appropriate cables.
Posted on Apr 02, 2011
How do i hook my compaq preario cq56 laptop to my hitachi hd plasma tv
The laptop looks like it has an external VGA port only and without knowing what model of Hitachi tv it is. It is quite possible the tv may have a VGA input in which case a standard VGA cable will allow you to connect the laptop to the tv. Otherwise you will need one of the following depending on what connections the tv has:
1. VGA to HDMI cable: http://www.amazon.com/Video-Cable-Black-Support-Necessary/dp/B002TUC64W/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697785&sr=1-1&keywords=vga+to+hdmi+cable
2. VGA to RGB cable: http://www.amazon.com/eForCity-Premium-Component-Cable-Black/dp/B0012SPNII/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697879&sr=1-1&keywords=vga+to+rgb+cable
If you do not have an HDMI input, you will also need to get an audio cable as well. Standard mini-stereo audio cables should allow you to connect the laptop to the tv.
Dec 16, 2012 | Compaq Computers & Internet
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Feb 03, 2012 | Panasonic VIERA Televison & Video
PLS HW DO I GET DRIVERS SOFTWARES VGA,SOUND CARD ETC FOR MY HP DUO CORE T2600...PLS
Please go to the manufacturers site and download the driver u needed! just type the model of ur laptop to any browser and it will direct u to the site, just follow the instructions and save ur downloaded files to ur flashdisk!
Jun 13, 2011 | Computers & Internet
I have a Laptop and an Acoustic Solutions Tv. But what i want to know is how to connect my laptop to the tv? What cables do i need? My laptop has the vga connection but the back of my tv will. i...
I believe the number that you have sent me is the serial number, Your TV should have a name and model #. For example (Sony Bravia model #00000) Yours would be RCA ? #?. The model number should be on the back of the TV. Is the TV an LCD flat screen? If it is and is fairly new it will have a special place to plug a PC into it. With the model name and number of your TV I can look for the manual and lok at the connection set up for your model.
Dec 28, 2010 | Televison & Video
I want to use my philips 29 PT8321as a monitor for my laptop
I think you need a VGA to Component Video Converter. You will need a VGA to VGA cable as well as the Component video cable and the converter box. One converter box: http://www.national-tech.com/specs/vga-to-component/40h1-50200.htm
You can check your video output specs: if your video driver can split the VGA signal into the different video components, then you just would need the component video to VGA adapter. (This is usually limited to working with projectors unless you have a higher-end stand alone graphics card.)
I hope this helps.
Apr 08, 2010 | Philips 27PT543S 27" TV
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
Cann't connect my PC to my TV
please conect your tv card to your pc and install his driver
Mar 17, 2008 | Nvidia TNT2 Vanta, (16 MB) AGP Graphic...
Projectile motion
Dear Sir,
I have NEC 42vR5 HW Plasma monitor, this plasma goes off with in 1 Minute, pls. give solution
thanks
pramod
Feb 24, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Enhanced video/TV missing in Device configuration
After looking at the specs of the think pad T43 i think you need a new laptop. The port you need to transfer video from a computer is called S-video. Your laptop don't have it. Srry.
You could look into some sort of breakout box that you could plug into your VGA out port and from there to a TV. The VGA out port is for adding a stand alone monitor and is not compatible with most TV's.
Jan 25, 2008 | IBM ThinkPad T43 Notebook
Hisense TL2620 26 in. LCD Television Logo
147 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
