Question about Magellan MAESTRO 3100 98083401 GPS Device
Gps I have not had my magellan gps for only aabout 8 months and used it three times and now it want even power up
  • 1 more comment
  • Anonymous Aug 05, 2008
    When I try to charge it or turn it on...it WILL cut on for a moment the shut off again...
  • Anonymous Sep 20, 2008
    Thanks for the hint about the reset button. I have been looking for 2 hours trying the support website, my support disk, etc. This quickly solved the problem.
    Thanks.
  • Anonymous Mar 23, 2014
    screen flashed two or three time before cutting off. GPS would not power back up or show anything on the screen except symbole to hook to a computer. no change even after reseting unit.
    Problem Solver:
  • 4 Answers
Use the reset button on the side.
Posted on Aug 23, 2008
After cleaning magellan GPS with windex the touch screen stopped reacting to finger touch commands
Slide power switch then slide and hold the power switch in the off position for more than 8 seconds. this will reset the device. you might have to do this a couple of times
If the above doesn't work, you should update your device software by visiting the content manager page of the magellan website
Content Manager
Apr 22, 2015 | Magellan GPS
How do i do a hard reset on a magellen maestro 4040?
  • 1 Slide the Magellan GPS unit's powericon1.png switch to the off position, if your GPS has a two-way slide-style switch. Hold the switch in the off position for 8 seconds or more to reset the device.
  • 2 Slide the switch to the reset position if your GPS has a three-way switch. These switches feature "Reset," "Off" and "On" labels. Hold the switch on the reset position for 10 seconds to initiate a reset.
  • 3 Inspect your GPS for a reset pin hole if the unit has a push-down power button rather than a switch -- check the bottom and sides of the device for a pin-sized hole. Insert a pin or a straightened paperclip into the hole, pushing until you feel a slight pop. Hold the pin or clip down for 10 seconds and the GPS will reset.
  • Read more: http://www.ehow.com/how_5635240_reset-magellan-gps.html#ixzz33LpAdUJE
    Jun 01, 2014 | GPS
    Magellan 315 frozen
    Occasionally, a unit will need to be reset. This can be due to software errors, firmware updates or simply at the command of technical support staff. A reset either will restart the unit, possibly clearing up any minor errors, or will restore the unit to the settings it was built with. There are three major Magellan units, which utilize different methods to perform this task.
    Things You'll Need:
    • A thin object (such as a paper clip)
    Using the stylus, tap "Main Menu" and select "View."
    Tap "Settings," and select "Restore Factory Settings." You will be given the option to confirm this action. Be sure that you want to reset to the settings that the GPS was built with. This action is irreversible.
    Tap "Confirm," and the unit will begin to reset.
    Maestro/Roadmate GPS Units
    Locate the button marked "Reset" on the left, right or bottom of the unit.
    Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
    If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
    Tips & Warnings
    • Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
    Jul 20, 2010 | Magellan GPS 315 GPS Receiver
    Maestro 3250 Stuck on Magellan Screen at Start Up
    go HERE, he/i will tell you how you can get it repaired free. this can be fixed but it requires a lot of time and patients..
    i dont think there is enough space here to explain fully how to restore the gps....you cant make it any worst but why waste your time if you can get it done for free.
    Aug 31, 2009 | Magellan Maestro 3250 GPS
    Gps will not turn on
    make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
    the following magellan 2000,2200t,2500,3000,3100,3140,4000 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it them selves
    you can email me through here or email to.... wmetz@comcast.net
    Jul 18, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
    The pin with which we charge the GPS was broke. is there anyway that we can open the GPS and fix it?
    no you cannot open it if the unit is under warranty call magellan and let them repair it but if the unit is no longer under a warranty magellan have a customer loyalty program were you can swap your old unit for a new one with a discounted price.
    Jul 03, 2009 | Magellan RoadMate 1412 Car GPS Receiver
    Battery
    BertM, I had the same problem and also do not use it frequently enough. The unit finally gave way about 7-8 months. I am hoping that Magellan will honor their warranty and find it's bad battery. I am awaiting an RMA. Visit following site for help:
    http://www.magellangps.com/support/askmaggie.asp
    Jun 18, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
    Will not come on.
    GPS units should never be permanently left in vehicles. The vehicle interiors get way too cold or hot depending on the climate you live in and is very damaging.
    Try taking it indoors and connect it via the supplied a/c wall charger and see if it turns on.
    Jan 24, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
    Magellan roadmate 300 wont turn on!
    I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
    Good Luck
    Nov 30, 2007 | Magellan RoadMate 300 GPS Receiver
    Magellan MAESTRO 3100 98083401 GPS Device Logo
    Top Magellan GPS Experts
    Will Halftowaite
    Are you a Magellan GPS Expert? Answer questions, earn points and help others
