Question about Maclaren Triumph Umbrella Stroller
Seat back i would like to know how to lock the back portion of the seat. when my son leans forward, the back of the seat moves with him. is there a way to keep it in place and lock?
There are poppers on the seat unit that attach to the chassis but they quite often tear, this is what has happened to mine and now i have to try and find spares!!
Posted on Aug 06, 2008
SOURCE:
Why does driver side power seat suddenly just move back and forth for only about a 1/4 of an inch?
These devices use motors with worm gears to provide the smooth operation and torque necessary to move the seat. The most common problem, other than the motors themselves failing (and since your does move somewhat, the motor is probably OK), the next biggest issue is something gets caught in the gear drive. Get a good look under the seat and see if there isn't something jamming the forward-backward motion of the seat.
Dec 15, 2015 | 2003 Chrysler Town & Country
Seat sloped too far forward
You need to be sitting in the chair and the middle lever is the one which releases and secures the angle. I find the adjustment is easier if you release the backrest lever, the third lever to the rear, lean back in the chair which will raise the front seating cushion while moving the backrest back. Using you feet on the floor push back in the chair until the seat feels better. When it is at an angle you like, push the middle lever down to lock the seat in place. Then adjust the backrest with the third lever.
Apr 08, 2014 | Tempur-Pedic Furniture
Remove front seat from 2005 ford five hundred
Move the seat all the way forward and remove the two bolts going into the cross bar in the back. Move the seat all the way back and remove the plastic covers where the front feet of the seat meet the floor. Remove the two bolts going into the floor. Lean the seat back and disconnect the electrical connectors.Lean the seat sideways so that the outside part is facing up and remove the nut holding the seatbelt to the seat and take off the seatbelt. The seat is now free to be removed from the car.
Nov 28, 2012 | Ford Five Hundred Cars & Trucks
99 grand prix power seat problem
check for something jamming the track under seat , try havin son push seat forward while pushin switch . i dont know of a way to override the seat motor if its dead,,auto wreckers for seat replacement cheapest way to go they may even install
Feb 03, 2012 | 1999 Pontiac Grand Prix
Automatic driver seat broken, how to fix/cost
The back and foward movement uses the same motor. So if it moves one way but not the other it's most likely the switch. Try to blow it out or clean it out. If pop or somthing spilled on it you will prob. need to pull switch out and take it apart to clean contacks inside.
Nov 10, 2011 | 2005 Kia Optima
The electrical seat wont move back up how to fix?
Common problem on these when seat moved all the forward, they jam there. Take a hammer and bang on the black exposed seat track while activating the seat switch to rearward.
The seat tracks are the portion that attach's the seat to the floor. Bang on the upper portion (the one thats attached to the seat).
Dec 18, 2010 | 1992 Toyota Cressida
My son inherited a Giant MTX 225 bike (I think a 2004 model). How do you adjust the handlebars closer to the seat (my son has to lean forward to reach them and it puts his back in an uncomfortable...
Stem length is the only dimension that can be modified, assuming the bike is not TOO long. They don't adjust in that direction but a Bike Shop can work with you to select one with a shorter reach and/or a different rise if necessary.
If your son has any desire to ride faster than 15mph or so for prolonged periods he's going to have to get his torso down and out of the wind, so a leaning forward postion would serve that goal.
Aug 04, 2010 | Cycling
How do I put down back seat in Chrysler LeBaron
position the seat as you know it fits best - putting each bottom leg over the hole in the floor. Lean the seat forward like you wanted to just get to the back of it - like if you leaned a kitchen chair forward. Now be sure the bottom portion of the seat is down in the hole a little - one on each side and then simply lean the seat back to an upright position. If it doesn't slip in and click - try spraying WD 40 or better yet - get a can of white lithium grease and spray that into the holes. LOOK CLOSE and STUDY the bottom of the SEAT and the little holders in the FLOOR - it will come to you they simply sit and lock onto each other. To remove the seat -- at the bottom of the seat is a handle pull - some have one on each side. pull this.
You can do this I can assure you.
Thanks
Gary @ Fix Ya
Jul 10, 2010 | 1994 Chrysler LeBaron
I have a 2007 ford fusion and i was driving one day and placed the seat belt behinf the headrest and now it is locked and there is not enough slack to move it. how do i get it unlocked ?
Try this:
1. On the door post, the belt holder can slide up and down. Slide it to loosen the belt tension, being careful to not let the belt tighten.
2. If no belt slack, try adjusting the seat back either lean forward or back, if possible.
3. You may have to move seat back / forth and adjust seat back a certain way.
Sep 24, 2009 | 2007 Ford Fusion I4 SEL Sedan
Maclaren Triumph Umbrella Stroller Logo
167 people viewed this question
Top Maclaren Baby Gear Experts
xxxxxx xxx
vanyell
Are you a Maclaren Baby Gear Expert? Answer questions, earn points and help others
