Question about Zanussi Dishwashers
I have a zanussi tempoline dishwasher, I have loaded this as I usually do, turn the knob to the right and select the 2nd programme the light next to this comes on, I have pressed this to start the machine although it seems as if it is going to start this light flashes and the top arrow on the right of this flashes intermitanly, but the machine does not start the wash programme. The 3hr delay button if I had pressed this by mistake which I am sure I have not would light up. When I found it did not work last night I cleaned the filter which had very little in it, put rinse aid in the correct compartment and put washing machine machine salt in it. I do not know what I am doing wrong. I believe the machine is less than a year old, can you help me please Ruth Ball (Mrs.)
  • Zanussi Master
  • 19,396 Answers
Hi Ruth.
The machine can be in error mode. In this case one or more lights in the control pad will stay on or flash and the cycle will not start.
One of the most common fault in your situation, and at start of the cycle is no water inlet. In that case you will need to check the water inlet hose at the back of the appliance.
Do not move the appliance yet.
First try disconnecting power by tripping the circuit breaker for few minutes, then re-program the cycle.
If that does not fix the problem, then try telling me the exact model number of the appliance, and describe exactly what lights come on the control panel when cycle does not start.
Alternatively contact Zanussi at the number listed on the user manual. The operator will guide you through a diagnostic, and then will decide if there is need for a technician or not. The machine is still covered with warranty. See:
Zanussi ' Contact Us
Regards.
Ginko.
Posted on Apr 02, 2011
SOURCE:
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
Mar 03, 2015 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
End of program?
check with Zanussi website tech support .
Dec 02, 2017 | Zanussi Washing Machines
Some 1 gave my daughter a slimline zanussi dishwasher not sure what model it is but looks quite old. need a manual as the program numbers have faded and cant see them regards chris oh and its a aqua save...
If the model is correct then even without a manual the control set up is as follows.
From Lhs you will see on/off/ button next are the 2 lights top one is on/off and the bottom is for salt low light.The next button to the right is rinse and hold next Intensive 70 Degrees,next Normal 65,next Bio 50, next Quick wash 50 Degrees.To cancel a wash programme open the door and press the button for the prog. underway for more than 1 second until the corresponding light goes out.
The dishwasher is now reset and you can select a new programme.You can try this site for a manual.
www.appliancehelponline.com
Hope this helps.
May 27, 2010 | Zanussi 18 in. ZDT5052 Slim-Line Built-in...
Dishwasher not filling
I WOULD REPLACE SOLENOID AND TIMER
Jan 17, 2008 | Zanussi 24 in. DE6544 Built-in Dishwasher
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Dishwashers Logo
3,512 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
