Question about Brother MFC-8440 All-In-One Laser Printer
3 beeps on button pressed
Every time I press a button (any), the MFC beeps 3 times and won't do anything. I restarted the machine and it does the same thing. This problem doesn't seem to be documented into the user manuel and I don't know what else to do.
  • Anonymous Aug 14, 2008
    ITs the same problem, how to fix it
  • klewis54 Nov 05, 2008
    same thing here.... ?? no idea what the problem is. it won't do anything at all! no fax, no scan, no copy, no print, no nothing!!
This work for me...the zero button was stuck on the numeric keypad. I would suggest looking over each one to determine if one of them are stuck as with mine.
Posted on Dec 17, 2008
Wow.....how easy. I had the same problem and as soon as I took the cover off the front to see if the 0 was stuck it strted working
Posted on Jul 17, 2009
I had this problem. Just like Geoff176 I had a stuck 0 button (why don't I EVER check the simple stuff). I just popped it up with a screwdriver and the unit functioned normally.
Posted on Jun 09, 2009
Reset brother mfc-9320cw fuser
1) Press the 3 and 9 buttons at the same time in the ready status.
2) "Reset Menu" will appear on the LCD. Scroll to Fuser by pressing up arrow or down arrow button then press the OK button.
3) "1. Reset 2. Exit" appears on the LCD. Press the 1 button to reset the fuser counter. The display briefly shows "Accepted".
The machine returns to the ready status after a few seconds.
Jan 24, 2012 | Brother MFC-8460N All-In-One Printer
Will not receive faxes or copy Fax line rings but the machine says its receiving but nothing will print out and it won't copy pages either I've tried turning the machine off for up to 5 minutes,...
To begin troubleshoot,you should set the machine to basic Fax/Tel mode only.
1 If it is not illuminated in green, press (Fax). 2 Press Menu/Set, 2, 1, 2. 3 Press ? or ? to select how long the MFC will ring to alert you that you have a voice call (20, 30, 40 or 70 seconds). Press Menu/Set. 4 Press Stop/Exit. Even if the caller hangs up during the pseudo/double-ringing, the MFC will continue to ring for the set time.
After you confirm your Brother MFC-5440CN is able to receive fax then you can pick one of the 4 modes as describe on the owner manual.
You can download it HERE Detail Information is on 3-10
Jul 28, 2011 | Brother MFC-5440CN All-In-One InkJet...
I have the phonemate 2970 answering machine/phone and satellite extension phone. When I turn the sat phone on I get a series of beeps and the HOLD light flashes for about 6 times then shuts down. I...
1. Remove the AC adapter plug from the back of the base unit (not from the wall); leave tel cord connected.
2. While holding down the "set code" button under the cassette lid, plug the ac adapter back into the base. The screen will then display some numbers (110) etc.
3. Hold down the HANDSET keys 1 and 2 simultaneously and then press the speaker button on top within 20 seconds.
4. Press any 3 digits on the handset i.e. 1-2-3.
5. After hearing a BEEP from the handset and base, press 2 on the handset. The base should then say "twenty-five", and the handsets will beep, confirming the new security code is enabled. Press talk or speaker on handset to confirm communication.
6. The time/day stamp and remote access code will be cleared.
7. Best to do this with the answering mach turned off.
8. Restart this procedure if anything goes wrong (may hear a series of error beeps).
I saved my manual and in it I had a fax Casio sent me with these instructions (i had this prob a few times years ago). Good luck!
Jan 18, 2011 | Casio PhoneMate PMP3875BK
The PS3 starts with the logo and the "waves" and
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, this method will erase your hard drive so any save games you had will be lost. All your online trophies will be preserved.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 5 "Restore PS3 System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. You will have to set your user name, date and time and network settings again.
Once you have completed the above, the Playstation 3 will restart and spring back to life again!
I hope this helps.
Jan 09, 2011 | Sony Playstation 3 (PS3) Console
Rental...no manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
Nov 07, 2009 | Washing Machines
Brother MFC-685cw stuck shutting down/standing by
Hold down that on/off button for at least 10 seconds without pushing any other buttons, wait after you release it and it should either wake up or shut down.
Aug 26, 2009 | Brother MFC-685cw InkJet Printer
Key pad on brother 1020e fax mc seems to be locked when you press copy for ex it just beeps 3 times
When the Brother machines beep three times while pressing any button on the front panel, this means there is a button stuck. Try pressing all buttons over and over to unstick button. This should help. Please rate my help if this works. If you need anything else, save my user name and ask me anytime. Thanks!
Jan 21, 2009 | Brother FAX-1020e Plain Paper Thermal...
Brother MFC-8500
what normally helps with brother is unplugging the machine for about an hour and plug it back in.
In your manual says how you can make a test print.
This will clear your internal buffer.
Also it might help un installing the machiine from your network and installing the software new.
try it and let me know what happens
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500 receives faxes and does nothing else
Check to make sure that the PC Fax Function is turned off. I noticed after I connected the 8500 to my PC and installed the software, I too could no longer receive faxes and it was corrected after I turned this PC Fax function off.
The function is located by:
  1. Press the MENU button.
  2. Select Option 2.
  3. Select Option 1.
  4. Select Option 8 (PC Fax) and turn that function OFF.
Hope this helps!
Brother MFC-8440 All-In-One Laser Printer Logo
544 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
