Question about LG WM1814CW Front Load Washer
Hey there our door has stayed locked after a wash (model WD-8026c) ,no previous trouble...any ideas?? turned power off,unplugged ,tried another cycle etc.My damn work clothes are in it lol.Any ideas that dont involve a sledghammer?
  • LG Master
  • 6,993 Answers
You might have to wait longer for the machine to cool before the door can open. Remove the washer from the wall wait for like 30mins, and try again. By then, the door should open with easy.
Also, note that;
many front loading machines have to be fully off, as in, the dial is on off and pulled out (or pushed in) whichever is the direction for "off." Otherwise there is a secondary latch on the door that stays shut to prevent accidentally opening it during a wash cycle.
If turning it off does and waiting for a while does solve the problem, remove the lower front panel use torx 15....reach up to the lock and pull down on a ring that comes down below the lock Assembly and the door should open. The problem however can be either the Lock assy easy and cheap to replace or the computer easy to replace but expensive.
Good luck.
Posted on Apr 02, 2011
LG Intellowasher WD-8026C having problems with the door latch, I keep getting an error message. Latch appears not to be connecting and locking the door. to start the machine.
The DE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly
Jan 31, 2015 | LG Washing Machines
I have a Kenmore Elite front loader model 42198900 , this morning shut the door ,light stayed on and no power to controls, any ideas
Did you ever get an answer to your issue? I am having the same problem. The light stays on when the door is closed and no power to the machine. I have unplugged it and done some other things to no avail. thanks
Jan 27, 2013 | Kenmore Elite 45986 Front Load Washer
Door won't open on my wd-8015c washing machine
This is a common problem, often associated with a momentary power failure when the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". Regardless of the cause, you will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
Additionally, on older machines with analog program selectors, turn the selector to an end of program setting before you power it off.
Jul 22, 2011 | Washing Machines
Hi there, I have an LG WD-8013F font loader washing machine that made a loud pop with a burning smell when I tried to run a wash program. I turned it off, and after a while tried the wash program...
semakan
  • memeriksa
  • menyemak
  • ')" onmouseout="ht(this)">check
    capasitor dalam tenaga
  • dalam kekuatan
  • ')" onmouseout="ht(this)">in power
    memasuki
  • masuk
  • memasuk
  • ')" onmouseout="ht(this)">enter
    that duduk di dalam')" onmouseout="ht(this)">staying inside.
    Nov 20, 2010 | Washing Machines
    Door won't open. door locked light stays on. I
    Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
    Thank you !!
    Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Indesit wd 125. Wash cycle had finished, door lock was off but
    Unplug machine, take lid off and locate the door lock. You will have to use a small screwdriver or something to release the lock. Then replace your door handle.
    Jan 19, 2010 | Washing Machines
    The door is bent a bit and now won't shut right unless slammed just right. I doesn't look bent but must be. I know I have trouble opening it after a wash where it seems stuck and I am sure the previous...
    That model has 2 hinges on the door, and one or both of the hinges are probably bent, not the door. The good news is that they are pretty cheap to buy the hinges, and it only involves 8 screws, its an easy fix. After you do that, if you still have problems with the door lock, then it probably got damaged from the door closing when it was bent, and you would need to replace either the door lock or the door strike if the strike on the door is broke. I have replaced many of these hinges for this problem, and havnt come across the door lock getting damaged in the process, but have had to replace a few broken door strikes. hope this helps, good luck.
    Oct 23, 2009 | Frigidaire FTF2140FS Front Load Washer /...
    Door lock will not releace
    Some door locks are powered by a solenoid.
    Have you tried unplugging the machine to see if the lock will release then?
    Jan 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
    LG Front Loader WD-8074FHB
    sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
    Mar 02, 2008 | LG WM1812C Front Load Washer
    LG WM1814CW Front Load Washer Logo
    22 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
