32" alba flat screen television
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards
Posted on Apr 02, 2011
Hello my 32' alba tv LCD32880H DF wont turn on. Instead of the standby light being lit as normal it is flashing
bad caps on power board.......
either repair caps or replace the board......
cheers
Nov 03, 2016 | Alba Televison & Video
How do i fix my alba TV the light at front flashes but I won't starte
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 17, 2015 | Alba Televison & Video
Alba tv flashing blue light tv turned itself off
If it turns off after a while that's a transistor going hot.
You need a technician to test it for you. If you want to do it yourself
let me know. Good luck.
http://www.tvrepair.localdomain.me
Jan 08, 2014 | Alba Televison & Video
Alba 32 inch tv when i turn it on the off/on light keeps flashing but the tv wont go on
check for a power supply failure, replaced capacitors with leak and bulged on its tops. that cause the dc output supply to drop.
Aug 13, 2012 | Televison & Video
Alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
Nov 18, 2010 | Televison & Video
Alba flat screen tv will not turn on and blue light is just flashing on front of screen
FAULTY POWER SUPPLY CAPACITORS ON POWER SUPPLY
AVERAGE COST OF REPAIR £60 TO £100
Aug 25, 2010 | Televison & Video
Alba servic mode
THE TV JUST GETS A LITTLE BLUE BOX ON THE SCREAM THAT SAYS CAN'T GET SIGNAL
Apr 05, 2008 | Televison & Video
221 people viewed this question
 Grubhead
Grubhead
