Reset lamp hours on the pentax epk 1000 - Office Equipment & Supplies
2 Suggested Answers
asnowman
  • 788 Answers
SOURCE: My TV model is Panasonic: PT-52LCX15. I have a
Here is a link to replacing the lamp and the instructions for resetting the timer.
I hope that this helps you.
asnowman
http://911phone.net/Panasonic_TY-LA1000_Instruction_Manual%5B2%5D.pdf
Posted on Jun 21, 2010
Projector clocked 1000 hours roughly and working fine. However 1 day I tried to turn it own and seems completely dead. no blue light. fuse r al good
Does this projector have an automatic timer that doesn't allow it to turn on after a set number of hours (@ 1000)? If so, you may need to re-set the lamp-hour clock (as if you changed the lamp even though you didn't). Some machines require you to at least slide open the lamp cover to make it think that you changed it.
Feb 13, 2016 | ViewSonic PJD6251 3D DLP Projector
Tip
How long does a DLP lamp last?
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How long does a DLP lamp last?
The most DLP Television last in between 1000 and 2000 hours this is whit the original lamp and depending on your brand.
Example the Philips lamp last between 6000 to 8000 hours and Osram like 4000 to 6000 hours usually the brand
Some lamps might last only 500 hours while others may last 3000 hours of life so check brand. And keep it clean of dust.
on Jan 27, 2010 | Televison & Video
The lamp does not attempt to turn on anymore on my Runco VX-1C projector. Power to the projector is good but lamp does not turn on.
I was about to chime in that you should reset the lamp hours after inserting the new bulb ... until I read that you couldn't see the menu because the bulb still doesn't turn on. Hmmm...
Have you checked all of the filters to ensure they're free of dust build-up? I'm wondering if it overheated which caused the fault.
Due to the fact that this model is out-of-production your options have become limited. I recommend at this point you give them a call:
Tech Support at 800-23-RUNCO
Jan 02, 2015 | Runco Reflection VX-1c Multimedia...
Why is the light strobing ?
Lamps will sometimes flicker when they are near the end of their life. Look through the menus and check the lamp hours, if it is over 1000 hours I would try another lamp. This could also be caused by the lamp ballast, which is the power supply for the lamp. If the ballast is bad, repairs will cost almost as much as a new projector.
May 01, 2014 | Epson EMP-X3 LCD Projector
I want to use my old k 1000 lenses on one of Pentex's new camera body's.
Your old Pentax lenses uses the Pentax K mount. The current Pentax digital SLRs all use the same K mount so the lenses will fit on them. You obviously won't get all the features available on new lenses, such as autofocus, but they should all work fine.
Dec 31, 2012 | Pentax K Cameras
I just replace my lamp but it says lamp life time is up replacement suggested
you need to reset the hours counter. look in the manual and it will tell you how to do it.
Mar 26, 2011 | Radio Shack Cinego D-1000 Multimedia...
Sony cineza vpl hs51 projector won't project
Something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
The lamp may not have been changed - just the timer reset - How many hours has the lamp really done - 1000, 3000, 5000?
If you know that the hours are genuine, then was the quartz bulb contaminated with a touch of oil from skin contact?
This will substantially shorten lamp life, due to the quartz going milky and opaque.
The easiest way to check, is to pull the lamp and have a look at the bulb.
If need be replace the lamp and reset the lamp timer.
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS51
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
Dec 07, 2008 | Sony Projector Lamp for VPL-HS51
LP130 projector - no light from lamp
there are several other issue that can arise with this unit
you may want to check out fixmyprojector.com
Jun 30, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
676 people viewed this question
k24674
