Question about Ricoh Aficio MP 2000 Black and White Copier
Can you advise what error code Sc121 is for a Riccoh MP2000Le?
  • Ricoh Expert
  • 287 Answers
Hello neil,
The Sc 121 means that the scanner that moves underneath the glass and illuminates your document and "scans" it did not return to its "home " position. There is a sensor under the glass towards the rear left corner that tells the copier when to stop the return of the scanner and establishes the scanner is it the correct position to begin its next scan. For both safety and image precision the copier HAS to know the scanner has returned home. You have a fairly new copier and I would not expect to see this error code on such a new machine.You may have a dirty/bad sensor, the motor that drives the scanner forward and back may be bad,you may have a mechanical bind that the motor cannot overcome, or the circuit board that is responsible for processing these inputs and ouputs may have went on vacation.I know I have defined the code and established the variables but have not given you a fix. Unfortunately I'm here and the device is there. I cannot provide you with any tests or tricks for this as this is area that is very delicate and precise and an end user is not prepared to mess with. All this is predicated on the assumption you have actually turned the RED main power swith off and back on to attempt to reset the code.If you are unsure of the location of the true main power switch then simply unplug the copier, and then re-energize. The code MAY reset. I wish I were more help, but at least if you have to have an on site service visit you may know right now more than the tech does when they walk in the door. Knowledge is powerful. Best to you. SPINAL
Posted on Apr 02, 2011
As i power on my ricoh mp2000le this is the error i saw. sc 829 code 301 detail ac000000. whats the meaning and solution?
here are some reasons.
1.Self-diagnostic Error: Optional RAM
The optional RAM returned an error during the self-diagnostic test
Resolution - ( Replace the optional memory board
- Controller board defective.
2.Charge roller current leak
The polling module detects a current leak of the charge roller. Causes as follows' • Defective charge roller
• Defective high voltage supply board
• Loose connection of the PCU.
Feb 26, 2015 | Ricoh Office Equipment & Supplies
Mp2000le sc390 - after excute develepor sc390 out..
Perform the TD sensor initial setting after clean the TD sensor.
Feb 13, 2013 | Ricoh Office Equipment & Supplies
Error code sc 541 in ricoh aficio mp2000le
Fusing thermistor open
Fusing thermistor disconnected
Fusing thermistor connector defective
Fusing thermistor damaged or warped
Fusing temperature -15% less than the standard input voltage.
Change the thermistor.
Nov 25, 2010 | Ricoh Office Equipment & Supplies
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Continual communication errors with Aficio
Turn on or off your error correction to see if it changes also try changing your phone cord.
Mar 23, 2010 | Office Equipment & Supplies
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
SC121
These are the possible causes of your "scanner error" (SC121). You'll need a tech to solve this:
* SIB or scanner motor drive board
defective
* Scanner motor defective
* Harness between SIB and scanner
drive motor disconnected
drive motor power source
disconnected
* Scanner HP sensor defective
* Harness between SIB and scanner HP
sensor disconnected
* Scanner wire, timing belt, pulley, or
carriage defective
Error code E007
Canon photocopier IR2016J show error code E007. Please advised me on how to resolve
May 05, 2009 | Office Equipment & Supplies
Ricoh Aficio MP 2000 Black and White Copier Logo
204 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
