Question about Sharp AM-400 Digital Multifunction Printer
Sharp fax machine AM 400.PAPER JAMMED.how to clear
3 Suggested Answers
Nic61
  • 1073 Answers
SOURCE: sharp am 400 driver dowmload for vista
There arent any drivers for AM-400 and vista!
AM-400 are only working whit XP, Milleniun and Win2000
Nic
Posted on Feb 03, 2009
SOURCE: fax sharp am-400
i need driver
Posted on Sep 11, 2009
How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
Jan 18, 2014 | Office Equipment & Supplies
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
Display says line error and print out says jam
• Check the connection. The cord from the TEL.LINE jack to the wall jack should be no longer than
six feet.
• Make sure there are no modem devices sharing the same telephone line.
• Check with the other party to make sure their fax machine is functioning properly.
• Have your telephone line checked for line noise.
• Try connecting the fax machine to a different telephone line.
• If the problem still occurs, your fax machine may need service.
Clearing a jammed document
If the original document doesn't feed properly during transmission or copying,
or DOCUMENT JAMMED appears in the display, first try pressing start/memory . If
the document doesn't feed out, remove it as explained below.
Important:
Do not try to remove a jammed document without releasing it as explained
below. This may damage the feeder mechanism.
Jan 17, 2011 | Sharp UX A255 Plain Paper Thermal transfer...
Can not reset machine from Document Jammed mode.
you will have to take this to a service agent as one of the paper sensors has jammed
Apr 09, 2010 | Sharp UX P100 Plain Paper Thermal transfer...
Saying paper jammed ..but no paper is jammed????
The course of the problem could well be when you pulled the paper the wrong way out ot clear the jam. Open the machine and have a close look at the unerside of the flap. There should be a micro switch, which could well be desloged.
George
Jun 01, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
Sharp fax - drum won't grab paper in order to send fax
Open the top and clean the rubber rollers with alcohol. Wife them well with a lint free cloth. Parae towels will put more junk on them.
Mar 08, 2009 | Sharp UX-B750 Inkjet Fax
Sharp uxb700 document jammed appears in the message window blinking-cant clear it. no sign of any paper jammed already tried unplugging and clearing memory
If you lift up the panel and look underneath there are two black plastic "levers" one to the right and one to the bottom of the black roller. The larger one on the right was stuck. When I pushed on it and it popped up the "document jammed" message disappeared.
Sep 05, 2008 | Sharp Office Equipment & Supplies
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
Mar 14, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
Help!!!
Carriage assembly is broken. Uneconomical to repair.
Jan 17, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp fax machine
Please help. Can Sharp UX-BD90 tel/fax machine be set to mute incoming calls?
Thankyou.
Jan 07, 2008 | Office Equipment & Supplies
66 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
