Question about Ryobi ZRRY46501 Factory-Reconditioned 12 Amp 3.42 HP Electric Tiller Cultiv
Ryobi RY46501A Cultivator Tines barely turn when off ground and under load will not turn at all. Any ideas what it takes to fix it? I assume it is a gearbox problem. I checked a part dealer and the gearbox was over $200 alone. I don't know if the gearbox can be repaired or not.
2 Suggested Answers
pranaclimbin
  • 50 Answers
SOURCE: Ryobi ry60514 tines won't turn
there are shear bolts that hold the tines on. they are designed to snap when u hit something big such as a big rock or pipe or something like that. they are designed to snap at so much pounds of pressure so u dont break any gears or gearshafts. a lot of times people dont realize this and put regular screws or bolts in it and run it. when they hit something they ussually snap the gearshaft inside the tiller. i have replaced this on my fathers tiller cause he did the same thing. so either u might need to put new shear bolts in or if u had a regular bolt in u probably snapped a gear shaft or a gear.
Posted on Dec 04, 2008
Tines won't turn
Detatch the HEAD and rotate it and then install it. There is a good chance you have Jammed the Head and this should reduce the pressure and allow it to work.
Apr 03, 2013 | Ryobi GC720R TrimmerPlus Add-on Garden...
Ryobi ry60514 is frozen.
Does the engine turn over? If not then it has most likely seized. If the engine turns but the blades won't then make sure you didn't wrap something around the tines causing it to bind up
Jan 17, 2013 | Ryobi Cultivator
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
I just bought a returned Ryobi GC430 at a reduced price at Home Depot. I took it home and topped off the oil, which was a little low, and put fresh gas in it. I finally got it running but the tines will...
Ryobi engines have a plasic camshft that when it get hot melts the lob off the exshast end and the engine wont run if it cant exshast remove the valve cover and you will see for yourself
Atlantis Small Engines
Aug 17, 2010 | Ryobi Cultivator
Ran fine now it seems like the engine is seized , only two years old the gas and oil mixture was fine it is a ryobi 60511b
take out plug and try to turn tines by hand and check the tines for free movement if free try to pull start it if still seized spray cylinder with penetrating oil and let sit if still wont turn over possible internal breakage-crank/piston rod
Mar 14, 2010 | Ryobi Cultivator
Tines stop under load
you have to get someone with a big tractor to "break" the ground up first. A tiller is just that...Not a plow
Jul 26, 2009 | Ryobi ZRRY46501 Factory-Reconditioned 12...
Tines do not rotate with any power
what kind of cultivator??? sounds like oil on the cutch or broken clutch need more info.
Jul 13, 2009 | Ryobi ZRRY46501 Factory-Reconditioned 12...
Ryobi (new) will not till forward. Model RY60502
mine did that until i raised the drag stake to barely touch the dirt and sometimes i have to raise the tines out of dirt and dig back in hope this helps
Jun 09, 2009 | Ryobi Cultivator
Nov 23, 2008 | Ryobi Cultivator
Ryobi ZRRY46501 Factory-Reconditioned 12 Amp 3.42 HP Electric Tiller Cultiv Logo
203 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
