Question about Zebex ZBA Z-3051HS Barcode Scanner - P/N ZB3051USB Handheld Barcode Scanner
I HAVE 5 SCANNERS, FOUR OF THEM SCAN AS THE ITEMS PASSES IN FORNT OF THEM AND THE FIFTH ONE NEEDS TO PRESS THE BUTTON. HOW DO I CHANGE THE FIFTH TO SCAN AUTOMATICALLY
  • 4,234 Answers
If you look in the manual, you will see the code to place the scanner in to "stand" mode which should do as you request. This mode is restricted to certain models however. Near as I can tell, there are a few variants of the Z-3051HS model that support this. Reference the manual at the link below. Please update this with any other questions you may have.
Thanks,
Dan
Link: http://www.zebex.com.tw/old_website/documents/users_manual/handheld/z_3051hs.pdf
Posted on Apr 02, 2011
HP Deskjet f4435 will print, but won't scan. Orange light blinks
When I press the scanner button the top power button starts blinking but the machine does not scan. I have not used the scanning function on this machine before. Please help...you may need to reinstall your ..
Aug 16, 2011 | HP DeskJet F380 All-In-One Printer
How do I change the language settings on my sansa fuze + mp3 player? When I first started it up, I accidentally hit the chinese button and need to change it to english instead.
Press the menu button. Scroll to the Settings (four vertical slider controls) and press the OK button (the middle of the round "joystick" control). Select System Settings (the last item on this menu) and press the OK button. Select the sixth item on this menu and press OK. Select "English" and press OK.
Dec 24, 2010 | Audio Players & Recorders
The language was changed to chinese -- how do we get it back to english?
1) Turn on the player.
2) Press the "menu" button in the bottom left corner.
3) Scroll and select Settings. The icon is a picture of four sliders next to each other.
4) Scroll and select the Language item, which is the fifth item on the Settings menu.
5) Select English, which is the top item on the Language menu.
Jan 25, 2010 | SanDisk Sansa E280 MP3 Player
How do i scan using a HP desktop F380
Deskjet F380 features a scanner within the upper portion of the device. "Scanning" an item describes the electronic process of converting pictures or text to data, then transferring that data to the computer as an image. Scanning an item into the computer is a simple task with the F380, the only limitation is the size of the item,
follow the steps below
Step 1
Turn the unit on by pressing the "On" button located at the top control panel. The control panel is located on the left side of the unit. The "On" button will illuminate to indicate that the unit is receiving power.
  • Step 2 Load the scanner with the item to be scanned. First, lift the lid of the F380 to the upright position to reveal the scanning surface. Place the item to be scanned face down onto the scanning surface. Position the item so that the edge of the item rests squarely against the front left-hand corner of the scanning surface, then close the unit's lid.
  • Step 3 Press the "Scan" button located at the lower left-hand corner of the F350's control panel to start the scan. If necessary, the scanning process can be stopped by pressing the "Cancel" button located just to the left of the "X" on the control panel.
  • Step 4 Save the scanned image to the computer when the scan is complete by clicking the "Accept" button on the window that appears on the computer's monitor.
  • Dec 29, 2009 | HP DeskJet F380 All-In-One Printer
    SCANNING ISSUE
    You need to install the complete software from HP Website or use the link belows:
    http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1140783&prodNameId=1140778&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
    After downloading and installing the complete software you need to set-up scanner.
    Using steps and i m sure your issue will be resolved.
    To program the Scan To button:
    Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
    Click the Setup to open the Scan To Setup Wizard.
    Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
    Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
    Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
    NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
    Click Update .
    To Create a destinations:
    Follow steps 1-2 from the above steps.
    Select Create a new destination with settings that I will specify and then select Next .
    Select the Save it to my computer and then press Next .
    Select the scan preferences and then select Next .
    Select the scan destination folder and file format type and then select Next .
    NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
    Select the quality level you would like the file to be saved as.
    Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
    Confirmation allows you to verify your settings. Select Save .
    Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
    Jun 28, 2009 | HP LaserJet 3050 All-In-One Printer
    Unable to scan 0n my HP3110 photosmart since changing to vista
    Download Vista drivers for your HP scanner and install the same.
    Apr 02, 2009 | Office Equipment & Supplies
    Xerox ducuMate 152, password recently does not work
    You could reset the device, that usually resets everything - the downfall is that you will have to re-configure everything.
    1. Right-click on the One Touch icon and choose Show Hardware from the pop-up menu.
    2. The Hardware Properties dialog box opens and shows information about your Xerox DocuMate 152 scanner.
    3. Click the Properties button.
    4. To return the scanner to its factory settings, click Reset Device.
    5. Click OK to save the changes and close the dialog box.
    If this doesn't fix the problem please post a comment, I will do some more research into it.
    Mar 20, 2009 | Xerox DocuMate 152 Pass-Through Scanner
    I cannot change the price for an item on CASIO TE-2400 register
    Hi. I'm afraid this is not a 'basic requirement' of a cash register. You are working with a very complicated area of cash registers that only the medium to high end machines can even do. If you are getting stuck already, then you will not be able to work out the more complex batch processing areas of scanning either.
    Your dealer should have setup the majority of this for you before you left their store (especially the keyboard layout issue and keysheet for the keyboard), then you would normally receive extensive training if you are going to be making program changes yourself in future.
    You will need to learn about the difference between flat PLUs and scanning PLUs, 'Not found PLUs' like you have run into so far, then deletion techniques, PLU status programming, manual entry using OBR method etc. The book is only a guide to what you should have learnt during training. You really need to go back to the dealer and get a training session. They should be able to sort out all of these problems for you. It will take a one on one demo to fully train the ins and outs of full scanning systems.
    Mark
    Nov 16, 2008 | Casio Parts Cash Register PC Desktop
    Scanning
    just have to put the item on top of the scanner glass with the image facing down then press the scan button to show the scan menu. If all setting are set just push the start button
    Jul 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    Scaning . . . Scanning. . .. not scanned
    Not sure if this is the correct way around, but it worked.  Go to Start --> All programs --> Dell Printers --> Dell Photo AIO Printer 922 --> Dell All-in-one center
    From here, you can determine and change your scan settings as needed;  then click "scan now" (thus by-passing the button on the actual AIO machine).  This scanned photos into my picture program so I could email to all the grandparents!
    Nov 14, 2006 | Dell 922 All-In-One InkJet Printer
    Zebex ZBA Z-3051HS Barcode Scanner - P/N ZB3051USB Handheld Barcode Scanner Logo
    94 people viewed this question
    Top Zebex Computers & Internet Experts
    David Payne
    David Payne
    Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
