Question about Silex Technology SX-2000WG (SX2000WG) USB Device Server
Sx2000wg message appear "failed to
Can a dynex DX-ESW5 act as a print server?
No. You need a router to set / obtain an IP or connect it directly to the computer RS232 serial port. No network required, but is old school and may be difficult. Specially with MAC. You are better off getting a new router.
Jan 29, 2013 | Dynex Dx-esw5 10/100 Fast Ethernet Switch...
Error Message "The server 192.168.11.1
The default name suggestions that no additional configurations have been done on the device out of the box. The default login should be "root" with no password. If this fails, see the source for information on resetting the device to factory defaults.
source: http://portforward.com/english/routers/port_forwarding/Buffalo/WHR-G125/Echolink.htm
Jun 26, 2011 | Buffalo Technology AirStation WBR2-G54S...
"Communications with selected server is lost while
Go into your web page and make sure your SMTP IP addresses and domain name entries are correct. Also check your DNS IPs and make sure they are current. You also may need to authenticate (name/password)
Feb 02, 2011 | Sharp MX-3501N All-In-One Printer
Hp proliant server dl380 g3. gettting PXE-E61:Media test failure, check cable how to fix it..
Your server tries to "boot" from several sources:
* floppy-disk
* CD/DVD
* disk-drive
* network (if you have a "boot-server" somewhere on your network)
So, if your computer FAILS to boot from the first 3 devices, above, it will try the 4th, namely via your network-adapter.
When your computer finds that its network-adapter is *NOT* connected via an Ethernet cable to a boot-server, it reports "check cable" and "test of the media has failed".
So, why did your server *NOT* boot from the 3rd device, namely your disk-drive? Solve that problem, and the 4th device (the "network-boot") will not be tried, and the error-messages will not appear.
Aug 27, 2010 | Computers & Internet
I am getting an error message that reads: "Auto-registration process fails to communicate." what does that mean?
This message is related with a Smart eSolution service on your device. This service allows your device to communicate with Xerox servers and provide meter information.
By not having the service configured or by not being able to contact the server you will be displayed with this message. (Re) configure the service is the solution for your "problem".
This will not influence the good production of the device. All services will be fully functional
May 05, 2010 | Xerox WorkCentre 4250SM All-In-One Printer
"Updating the destination list has failed" Error message on Savin
It is a communication problem that's all.
I may or may not be able to help.
Are you using a scanning software on your server to scan to folders? for example "Scanrouter V2"? -you can check on your server in "start" , "programs", you will see it there if it's installed.
If so do this:
open "Scanrouter V2 admin utility"(you should just have to click 'OK' when asked for password -it's usually not set) then and under the "server" button select "set I/O device", then select "remove". If you are asked to "retain settings" select "no". Then add it again> click "add", then "Browse", it should find the machine (either host name or IP address), select "ok" then name it whatever you want - it's for identification only. Destinations should re-appear if you Update.
If you scan via SMB, Email or otherwise, you'll have to get your IT dept, or whoever configured in the firstplace to figure it out.
*please rate response :)
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Silex Technology SX-2000WG (SX2000WG) USB Device Server Logo
37 people viewed this question
Top Silex Technology Computers & Internet Experts
David Payne
David Payne
Are you a Silex Technology Computer and Internet Expert? Answer questions, earn points and help others
