Question about Microwave Ovens
My hotplate is locked. new house no info book no idea how to unlock it. its a franke glass electric cooktop
    Brigadier General:
  • 8,909 Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Apr 02, 2011
Replacing the ceran glass maintop
Actually if you've removed the 2 or 3 screws at the front (underside) of the cooktop, you can lift up the front. Prop it up with a board, and then remove the 4 screws that hold the 2 brackets that hold the 4 elements to the cooktop. Now pull the cooktop forward a bit, and you should see a green ground wire attached to the back of the cooktop. If not, then don't worry about it! Just pull that cooktop up and off the range. You will need to transfer the 2 tabs in the back of the cooktop, and the silver steel bar located at the front of the top to the new cooktop. Then reverse the process to install the new cooktop and re-fasten the elements to it.
Apr 22, 2014 | Kenmore Microwave Ovens
Hot plate just wont turn on...switches checked in meter box and no iscolating switch. baumatic ceramic cook top. BA 13.2 ( i think) house just been sold. Hotplate wked thurs. House sold Fri. new owner...
Hello, is this a two electrical filament hot plate? Also, is this range stove/oven? I'm a little confused here on what exactly what you are referring to hot plate or cook stove with electrical burners and oven. If it a really old hot plate with one burner look at the plug there could be a fuse in it. If it is electrical range then check the control board and see they a fuse on. If not, check the voltage with a volt meter. Be very careful here there two phase that is 240 Volts AC. The voltage will be split between the two l20 hot legs AC which is 120 degrees out of phase in respect to each other; in other words, don't both of them don't let them touch each other.
If it a kitchen stove I'm fairly sure that the control board is shot and with this not operating it will not open the current/voltage relays for the electrical burners. REMEMBER YOU ARE DEALING WITH 240 VOLT AC...BE CAREFUL.... GB....stewbison
Aug 26, 2011 | Baumatic Microwave Ovens
I have a GECE7006 induction cooktop and next to the timer button it is flashing "Lo" and i cannot clear it to use any of the hotplates?
Remove the main power for about few hours and then plug the unit while you press the Start/Stop button. If the panel still blinks around, check for any traces of moisture on the panel. if so dry and check. If not the processor is having some errors which needs to be checked from within and requires Tech help.
May 19, 2011 | Baumatic Microwave Ovens
HOW TO UNLOCK JEN-AIR STOVE TOP MODEL# JED4536WR01
The All Off cooktop touch control turns off the downdraft exhaust
system and all surface cooking areas that are in use at the same
time.
The Lock cooktop control avoids unintended use of the surface
cooking areas. When the cooktop is locked out, the surface
cooking areas cannot be turned on by the cooktop touch
controls.
To Lock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds. After 4 seconds, ALL OFF/LOCK will glow red,
indicating that the cooktop controls are in the lockout position.
To Unlock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds.
Apr 24, 2011 | Microwave Ovens
Hi, We have MAYTAG schott ceran flexchoice glass cooking top. Even after cleaning it with a ceramic glass top cleaner,stains are remaining on it. Can u please suggest what is the best way to clean it .
Sudha3025 -
Sorry to hear you're having trouble getting your cooktop clean.
You mention you are using a glass-ceramic cleaner but I would also suggest scrapping the stains with a NEW metal razor scraper. A cooktop scraper is similar to one you would use to scrape paint off your windowpanes at home and you can typically find them at a hardware store. The razor won't damage the surface like other abrasive sponges might. For best results, hold the scraper at approximately a 30 degree angle to the cooktop and protect your hands by wearing an oven mitt.
Also try using a Wieman sponge in conjunction with the cleaner on those stubborn stains.
As always, try to clean up spills, especially sugary ones, immediately when they happen, or get them away from the hot burner area and clean after every use.
Hope this is helpful!
Apr 07, 2011 | Maytag Microwave Ovens
We have a Kenmore model 721 microwave. How do I get to the light bulb to replace it? Thanks, Frank
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Jan 17, 2011 | Microwave Ovens
I have a Brandt induction cooktop and 2 hotplates don't work at all and the other 2 now don't appear to be connecting with the saucepan. Heat light starts to flash then turns off completely. Unable to...
Sounds like a wiring problem,take off of course with no power and check it out. No harm if no power,and replace wire and or componet with same.
Jan 11, 2011 | Brandt Microwave Ovens
My gas hotplates ignition switches are not working. How do I fix this.
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 02, 2010 | Microwave Ovens
Glass door
It doesn't appear to have been involved in a recall, but since its a non-US model, I probably can't get much more info on it.
Many if not most glass suppliers from the phone book will handle tempered glass too.
Apr 27, 2008 | Microwave Ovens
Panel Locked
Press and hold CLEAR/OFF for about 3 seconds to lock and unlock. Download manual on link below: http://www.abtelectronics.com/images/products/PDF_Files/SCA1000-SCA1001_om.pdf
Jul 27, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
88 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
