Question about Coleman Hot Water On Demand
I am having trouble with my coleman. i charged it before, just to make sure it was good to go. the unit say's it is fully charged, i then put the pump in a full 10lt bucket of water, connected the gas bottle and turn the gas on; then turned the knob around to hot but nothing happened. so i checked the battery which has 6.2 volts, and when the charger is plugged in it goes up to 6.5 volt so i guess that part is ok. is there a fuse in this unit? i'm not sure if the pump is faulty or if there is any power at the outlet of the main unit. Is the center pin of the pump cord positive or negative. this is only roughly 3 years old and has only been used on about 4-5 camping trips away.
3 Suggested Answers
SOURCE: Have three coleman hws same problem on last
It will probably be one of two issues. Either the waterflow sensor is not working correctly or the propane valve connected to to control knob is stuck shut. The water flow sensor is located on the side of the copper element (grey box) check that it spins easily. The propane valve is attached to the control knob by a long metal wire and should turn freely as you turn the control knob to warm
Posted on Aug 31, 2010
SOURCE: coleman hot water system has been charged for 3
Water heater will spark but will not ignite. Full Gas and Batt
has worked like a charm for two years
Posted on Sep 14, 2011
I was given a coleman Powermate 400 watt inverter I hooked it up to a car battery and the fault light immediately started flashing I do not have a manual based off this being given to me.
I'm sure you can easily get a PDF manual on-line somewhere.
My guess is that sometimes these inverters will give an error if you do not have something plugged in creating an electrical draw
Mar 02, 2016 | Coleman Electrical Supplies
How long do I charge a Coleman powermate cordless vacuum Mod. 6990
It should be fully charged in 8-12 hours. Charge it overnite and you should be good to go.
Sep 09, 2014 | Electrical Supplies
We modular home in 2008 with a coleman furance model number DGAA090BDTB we have had nothing but trouble with the furance, the latest thing we found out the heat exchanger was cracking. We have had...
if the heater is a 2008 also then there should be a warranty still on the heat exchangers, i have installed modular units such as coleman ,intertherm, and nordyne common modular home units inthe past and at minimum the heat exchanger should have a manufacture warranty of at least 10 years on it... and up to 20 on the heat exchanger not exactly sure what the warranty is on this but can guarentee it should have at least a 10 year warranty...call manufacture with your model and serial number and they can give you warranty...then get a reputable company out to do the repairs...good luck to you that really stinks
Jan 08, 2011 | Coleman Heating & Cooling
Coleman Spotlight PML8000 lasts only a few minutes when charged
your battery is gone. chk with coleman for replacement
Dec 13, 2009 | Cars & Trucks
My unit doesnt pump and the fire will only light for a couple seconds
Does the low battery light come on straight away even though it is fully charged? My unit did this and I found the impeller for the pump stuck. Try taking off the filter off the end of the pump get a nail or long screw and spin / free the impeller and try and use the coleman again. If this works I suggest cleaning the unit as per the book with clr etc
Sep 08, 2009 | Coleman Hot Water On Demand
Coleman powermate 1850 charge time
i advice you not to keep it plugged in too long...just about enough to get it workin....
:had a bad over-charge axcident..
Jul 16, 2009 | Electrical Supplies
Coleman Junk!
Batteries are still evolving and have not been perfected yet. Some batteries still develop 'memory'. This can be 'cured' by discharging battery completely to dead. Then recharge fully. Do this at least two times.
Jul 13, 2009 | Drills
Need solar panel monitor for coleman TSR
Wire it direct to batteries. It puts out very little amperage, so not to worry about overcharging the batteries. It's only basically a trickle charge.
Jul 10, 2009 | Coleman Mach 15 Air Conditioner
Burner lights and then goes out almost immediately
http://www.coleman.com/coleman/images/pdf/2300-700.pdf
Trouble shooting guide
Mar 14, 2009 | Coleman Hot Water On Demand
HAVE A COLEMAN MODEL DRHSO601CB --- THE UNIT WILL RUN FINE FOR SEVERAL HOURS WITH GOOD COOLING AND THEN PERIODICALLY THE TROUBLE LIGHT WILL COME ON THE THERMOSTAT AND THE UNIT HAS SHUT DOWN. TO RESTART -...
You may have a low pressure or high pressure switch tripping out the board as well. You might try cleaning both the indoor (evaporator) coil and the outdoor (condensing) coil. Be sure to turn off the power source before servicing this.
Jun 30, 2008 | Coleman Heating & Cooling
Coleman Hot Water On Demand Logo
90 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
