TI CALCULATOR[OLD]TI 500511
I'm trying to find someone to help me re-set my calculator from TI. I know it's an older model, but it still works just fine up til now. For some reason, it prints out different amounts than what is entered and now a diamond shape appears on the right side of the amt. Window shows the amt. and whatever step is being done. Print-out shows nothing to compare with the window display.
I would appreciate any advice if possible to e-mail how to correct the problem. I think I might have accidentally put my hand on the memory keys as I was re-adjusting the pulley belt that had slipped off.
THANK YOU FOR YOUR TIME.
M. EDMONDS
SOURCE: Won't print/feed
Try removing the batteries in addition to reseting the calculator.
Posted on Nov 29, 2007
oldnovii
  • 667 Answers
SOURCE: HP 32 won't work
Hey Dave- take a look at the following link. I like to have the user actually look at the user guide instead of describing it. If this solves your problem PLEASE rate this as fixed. If this isn't exactly right or you need more help just add a comment and I'll be glad to help you further. Thanks.
http://h10032.www1.hp.com/ctg/Manual/bpia5305.pdf
Jeff
Posted on Apr 30, 2008
SOURCE: CASIO DR250TM CALCULATOR
In case you haven't found the solution yet. This is it.
Move buttons to "Print" and "F"
Press CA key
Press % (set Key)
Press "time"
Press and hold down the % (set key) until the numbers come back and start flashing.
Put in the correct numbers.
Press % (set key) again and your done.
Hope this helps.
Linda
Posted on Feb 11, 2009
SOURCE: Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Posted on Mar 16, 2009
  • 102366 Answers
SOURCE: Low screen display contrast
Adjust the display contrast by pressing and releasing the 2ND key, then pressing and holding the Up key to increase the contrast or the Down key to decrease the contrast.
Posted on Jan 23, 2010
Ti-36x Solar Scientific Calculator issue: number buttons resetting to zero...
Look in the back of the calculator, some TI models have a pin hole to hard reset the calculator.
Mar 22, 2015 | Texas Instruments - Ti-36x Solar...
Ti nspire calculator. calculator will not turn on. installed new batteries, calculator only 2 years old with moderate use by daughter for school. ti cares sent me a link on troubleshooting, methods did not...
I have fixed several TI calculators for a school that had loose or corroded battery contacts. Cleaning the contacts and bending them a bit to get a good grip on the batteries got them going. You can try this on yours and see if you have any luck. Also try another set of batteries on the off chance one of the new ones you installed is bad (it does happen, and isn't one of the first things you'd think to check) or use a battery tester. If the batteries are good and the calculator still doesn't work, something inside has failed. Either go for the refurb or (if that specific model isn't required for school) see what similar brands and models are available. There might be something suitable for less than the TI price.
Jun 30, 2011 | Texas Instruments TI-Nspire Graphic...
How to do nPr or nCr on TI-30x Solar (scientific calc.)
If you have an older version on the TI30x Solar (not TI30Xa or newer) then you must use a different key sequence for nPr/nCr.
52 [2nd][x/y] 5 [2nd][nCr] gives 2598960 (the x/y button is above the Pi symbol on my version).
8 [2nd][x/y] 3 [2nd][nPr] gives 336
This took me forever to find out, so hopefully it will help someone!
Jan 27, 2010 | Texas Instruments TI-84 Plus Silver...
My calculator only works when it wants to. when i turn it on and press any button a 4 shows up on the screen. if i take the batteries out for a while and then put them in for a day and then try to use the...
The last question first. To verify if Texas instruments will send you a new calculator in exchange for the old you have to contact them.
TI Contact Information
TI-Cares Customer Support Contact a TI-Cares Customer Support representative via e-mail or phone to order products, inquire about issues, or ask general questions about TI education technology.
1-800-TI-CARES (800-842-2737)
Monday - Thursday: 8 a.m. - 7 p.m. Central Time
Friday: 10 a.m. - 7 p.m. Central Time btn_download.gif Contact TI-Cares Support
TI-Cares Technical Support Our Technical Support Group is trained to answer your technical questions about TI calculators, software, and accessories.
972-917-8324 (This is not a toll-free number)
Monday - Thursday: 8 a.m. - 4:30 p.m. Central Time
Friday: 10 a.m. - 4:30 p.m. Central Time btn_download.gif Contact Technical Support
While you are waiting for the eventual arrival of your new calculator, we may try to diagnose the ailing of the old one.
  1. Remove the old batteries. Buy a new set of batteries.
  2. Prepare the connectivity cables needed to connect the calculator to the computer. Choices are the TI USB silver cable, or the TI Graphlink Black serial cable.
  3. From education.ti.com, download the connectivity software compatible with the cable you will be using from this site. In all probability you will need the TI Connect 1.6 for Windows or Mac.
  4. From education.ti.com, download the latest operating system
  5. Install the Ti connectivity software on your computer.
  6. Wait for a day then insert the new batteries.
  7. Turn calculator ON
  8. Execute the TI Connect software.
  9. Connect calculator to computer.
  10. If you have an active Internet connection, click the Updates button on TIConnect main window.
  11. The software will download the latest OS and install it on the calculator.
  12. If you do not have an active Internet connection, run the TIConnect software.
  13. Connect calculator and computer. Turn calculator ON
  14. Drag and drop the OS which you downloaded on the TIConnect main window.
  15. The software will attempt to install the OS,
If for some reason this does not work, you can transfer the OS of a working calculator. You will need a cal-to-calc USB miniA to miniB cable or a calc-to-cal I/O cable.
Dec 15, 2009 | Texas Instruments TI-84 Plus Calculator
Ti 84 not working
Since it gets tossed around a lot, it is possible though improbable that the batteries lose contacts with the electrical terminals.
You may try to darken the screen a bit.
1. Press [2nd] key and release it
2. Press [UpArrow] and release it.
3. Repeat steps 1 and 2 in sequence until contrast is satisfactory.
If that does not fix the problem, use a calc-to-calc cable and try sending something to it from a working calculator.
You can also download the TIConnect software from education.ti.com and install it on your computer. Then connect the calculator to the computer by means of a USB cable, a TISilverCable, or a TI Graphlink (Black cable). Turn the calculator ON, run TIConnect, connect calc-to-computer and Click TIDEVICEINFO in TIconnect main window.
If it tells you NOT FOUND, on any of the ports, click the communication settings: Set the device type to you calculator model. Set the cable type. Set the port (COM x) or USB1
If calculator is not detected through any of the available ports (COM ports, or USB), then it would suggest that calculator is in need of repairs.
Hope it helps.
Sep 26, 2009 | Texas Instruments TI-84 Plus Calculator
Ti-84 plus
this might seem weird.... but have you checked the brightness of your calculator? if someone was playing with it and set the brightness to 0 it wont seem like there is anything. if u press second then hold the up arrow key it will make the screen darker. I dont know if this will help you or not but i know some of my friends like to play pranks where they set the brightness really high.
Sep 24, 2008 | Texas Instruments TI-84 Plus Calculator
Ti85
kinda. The TI-85 programs differently, lacks a table feature, is not upgradable, has redefinable keys, has a larger screen, is smaller, energy efficient, TI-86 semi-compatible, and is older.
The TI-84+ has archive memory, flash-upgradable, FSTN (clearer) screen, 16*8 screen, USB On-The-Go compliant, almost a centimeter longer, assembly language support, and a tad bit faster.
TI-82: $89
TI-83 Plus: $79-99
Free TI-85: $0
TI-84 plus: $119.99
TI-84+SE: $129-139
TI-89 Titanium: $149
Sep 06, 2008 | Texas Instruments TI-85 Calculator
TI 84 plus
I had the same problem. Found a posting on Youtub of someone messing up their TI-84 for fun by sticking a paper clip in it... One on the comments noted that dust in the data port can also cause it to not work right. I did not see anything dirt or dust on/in my TI-84. But I went ahead and took a can of compressed air and blasted the data port. Problem solved, it's been working fine ever since... If you have a receipt, and it's less than a year... TI replaces for free... other wise it cost $55 + $6 for shiping... 1-972-917-8324 is their number... Why it's not an 1-800.... I don't know... Hope this helps
Sep 20, 2007 | Texas Instruments TI-84 Plus Silver...
63 people viewed this question
jasbo
jasbo
