Question about ICP DAS I-7561 CR (I7561CR) Serial Adapter
Driver incorrect Hi! I can't find a driver which will work correctly with my I 7561 CR. Please, help me? What for are program eewriter.exe on the install CD?
Hello, look the device VID & PID in
Control Panel --> System --> System Properties --> Unknown Device --> Details
Es. I Found on my notebook : USB\VID_067A&PID_7561\5&1737F18D&0&2
Then Modify SER2PL.SYS with your VID & PID
Es. :
ExcludeFromSelect = USB\VID_067A&PID_7561
%DeviceDesc% = ComPort, USB\VID_067A&PID_7561
Reinstall the driver
Posted on Sep 23, 2008
Fackin admins!!!!!!!!!!!
Posted on Sep 08, 2009
Help 68538702001
Here's what I would try first:
  • Open Device Manager and look at the properties of the device and all USB Root Hub entries. Under the Power Management tab, deselect the check-box for "Allow the computer to turn off this device to save power".
  • Don't let the computer go into Sleep mode under Power Management.
Also, I would think a serial device might draw a lot of power, getting pretty close to the 500 ma limit imposed on USB ports. The device might be more dependable if connected to a powered USB hub, which might not have this limitation.
Dec 12, 2013 | ICP DAS I-7561 CR (I7561CR) Serial Adapter
I need motherboard driver for asus p4s533-x
you can download all your driver software for your Asus P4S533 from here.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Aug 18, 2011 | ASUS P4S533-X Motherboard
When i downloaded adobe acrobat, all i seem to have is a file that opens with text edit and is alot of numbers. What do i do to download it correctly?
The file you have downloaded is OK. The problem is with your PC.
When you double-click an .EXE file, the program may not launch, instead it may open in Notepad (displaying the .exe contents), or may launch in any other application like notepad. It is due to the incorrect .exe file association caused accidentally or probably due to a virus activity and you get the result similar to the following:
Download EXEFIX-XP
EXEFIX utility and save to Desktop. Double-click the file to run it. This utility fixes the .exe file association in the registry automatically.
You may also use REGISTRY PATCH (for Windows XP)
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
Jun 12, 2011 | Adobe Acrobat 7.0 Professional
I'm trying to uninstall some programs from my computer but it dosen't work, what should i do?!
Hi hugoluannpch,
If you are trying to uninstall few pre-installed Software in the Computer (like trial version Software), you can use the VAIO Applications Uninstaller Software. This Software can be downloaded from the your Computer model home page.
Below is the link to download the VAIO Applications Uninstaller Software.
This should help you to uninstall the Software.
Hope this helps.
Please post back if you require further assistance.
Thanks for using Fixya.
Oct 19, 2010 | Sony VAIO CR Series Notebook VGN-CR290EAN
I am using compaq windows vista. I want to connect and use visioneer4400 flatbed scanner. I do not have the disk. How do I install the driver and use
Well there is no driver for your scanner that support Windows Vista.....
Anyway Please follow the below steps -
1) Go to -
2) Downloaded the driver.
3) On your local machine right click on the 42bit.exe and select properties
4) Select compatibility tab
5) Select the run this program in compatibility mode for Windows Vista.
6) Privilege Level select the box "Run as Administrator"
7) Select OK or Apply.
8) Run the 42bit.exe and install the driver
9) Plug in scanner and driver should load correctly.
10) Go to Start -> All programs-> Windows fax and scan application and test it out.
Good Luck!!
Dec 08, 2009 | Visioneer 4400 Flatbed Scanner
Vaio Care & Vaio Sat Survey.exe has stopped working
Hi guys. I'm a Technical Support Agent for the Sony VAIO.
Please open the C: Drive > Programs x86 Folder > Sony > satsurvey or survey, then, delete the vaiosatsurvey.exe File from there. It should successfully resolve the issue. Hope it helps. I took remote sessions and resolbved many issues.
Jun 11, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Incorrect Port Detected
According to Features and Specs on Lexmarks website, this is a All in One? i.e Fax, Printer, Scan & Copy? also it's a Network type?
If so have you chosen the correct settings via the Printers Dispay and Control Panel? ...... I assume you have and everythinh in Device manager looks good, i.e no Yellow and or Red Icons over anything listed there, especially USB....correct?
If your Vista is the 32 Bit then the driver file should be: cjb5000enOSS.exe (87.7MB)
If Windows Vista x63 then it will be: cjq5000enOSS.exe (132.76MB)
Hope the above helped,
Jun 02, 2009 | Lexmark X5075 InkJet Printer
I need a audio driver for my versapro va10h window xp
this is the link of nec versa pro drivers
Oct 27, 2008 | NEC Versa VX Notebook
ICP DAS I-7561 CR (I7561CR) Serial Adapter Logo
1,746 people viewed this question
Top ICP DAS Computers & Internet Experts
David Payne
David Payne
Are you an ICP DAS Computer and Internet Expert? Answer questions, earn points and help others
