Computers & Internet Logo
Anonymous Posted on Apr 02, 2011
How to restore system to original settings from boot. kogan e10-02 reset password
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
123
Points
Want to change my description in my profile
  • Anonymous May 18, 2011
    Direct me on how to change description in my profile
What F? Key do I press to restore my Fujitsu Siemens amilo L7320GW
Fujitsu simens back to factory settings
Downloads & Disks Regarding The Reset Factory Settings Fujitsu Amilo Li 2727
http://www.user-guides.co.uk/download/reset/resetfactory/reset-factory-settings-fujitsu-amilo-li-2727.html
Fujitsu Laptop to Factory Settings
Restoring the factory settings on your Fujitsu laptop is a great way to get rid of files associated with programs that have been removed from your computer that are taking up space and get rid of pesky viruses that you can't remove from your machine by any other means.
Restoring the factory settings on your laptop can also help resolve problems with an unstable laptop.
You should also restore the factory settings on your laptop if you plan on selling it or giving it to a family member or friend.
Restart or turn on your Fujitsu laptop. Press "F12" repeatedly when the Fujitsu logo appears on the screen to be redirected to the Boot Menu.
Highlight "Recovery and Utility" using the arrow keys on the keyboard, then press "Enter."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files.
When the files have been loaded, the System Recovery Options window will be displayed.
Select a keyboard layout, then click "Next." The Operating System dialog box appears.
Choose "Use recovery tools...," then click "Next." If prompted, type your administrator password, then press "OK." The System Recovery Options window will appear again.
Select the "Recovery" tab, then click "Restoring the Factory Image (only C:\drive)."
The restoration process will begin, and the laptop will be restored to its original factory settings.
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen.
Begin personalizing your copy of Windows.
Using Boot Disc
Highlight "CD/DVD" using the arrow keys, then press "Enter."
Place the boot disc that came with your Fujitsu laptop in the optical drive, then click "OK."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files. When the files have been loaded, the System Recovery Options window will be displayed.
Click "Next" when the Operating System dialog box appears.
If prompted, type your administrator password, then select "OK."
Click "Recovery and Utility" when the System Recovery Options window opens, then select the "Recovery" tab.
Click "Restoring the Factory Image (only C: drive)."
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen. Begin personalizing your copy of Windows.
Saving and recovering your factory and system images.
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/HDD Restore Generic-Multi-lang B6FJ-3031-03EN-00.pdf
Hard reset
You may need to restore your Acer computer to its factory defaults if a virus damages operating files or if the system begins acting erratically for unknown reasons.
Restoring an Acer to factory defaults returns the computer to its original state when first purchased.
Click on the Start menu.
Then, select all programs, Acer Empowering Technology and Acer eRecovery Management.
If this is the first time you have opened the program it will prompt you to set up a password and create a backup CD.
Click the Restore button and select the option that reads "Restore system to factory defaults".
Wait for the computer to finish the restore process and reboot.
Restoring for the Boot Screen
If your computer will not boot up properly, you can attempt to reach the restore option by pressing the Alt button and the F10 button at the same time.
When the eRecovery menu appears, choose "restore system to factory defaults".
Wait for the recovery process to complete and the computer to restart.
2answers
Will not restore also saying password is wrong but it's not I'm completely locked out
If windows is saying your admin password is wrong, you can reset it by booting from Hirens Boot CD, booting into Mini XP and running NTPWedit to blank out any passwords.
3answers
Right. i have a toshiba nb305-106. i forgot my password and want to restore to factory settings. i don't have a removeable passwrod back up on a flash drive and holding the 0 (zero) key doesn't...
There is a software called opencrack download it and burn to cd then boot from it you have to follow the instruction then you can reset the password or if you have original Toshiba restoration cd use that but it format all your files.
How do I reset my password that I forgot on my Dell Vostro 220
if you forgot the password for tyour winows log in theres no real easy way to change the password. one way is to get a password recovery tool. you have to be carefull because there is a alot of scams out here. in my experience heres the top five i suggest
  1. Stellar Phoenix Password Recovery - Simple startup utility resets a forgotten admin or users' password using a familiar Windows-like program interface instead of command-line.
  2. Password Kit - Top rated version of Passware's Password recovery app, supports Windows Vista and RAID/SCSI/SATA drives.
  3. Petter Nordahl-Hagen's Offline NT Password & Registry Editor - A great boot CD/Floppy that can reset the local administrator's password.
  4. Openwall's John the Ripper - Good boot floppy with cracking capabilities.
  5. EBCD - Emergency Boot CD - Bootable CD, intended for system recovery in the case of software or hardware faults
  6. the next step i could recommend if you do not want to do this is to try a system restore. if you have the system cds that come with the computer you can put them in and when starting up computer you should see setup or system restore in bottom right or left corner. it will say hit f12 or f2 you are going to want to go into there and boot from cd. once you boot from c you will be able to do the system restore and set computer back to factory defaults.
2answers
How do i reset my acer my sister put a password on it as a joke ,she cant remember
When you boot up to the log in screen type in administrator to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings
hope this helps
Ran an image restore, but given me a login request for Administrator password. I set up a password the 2nd time I did the restore, but it's not recognizing my password when enter the 2nd time around which...
only administrator account has the priviledge to restore a system and it 's the password which you assigned for administrator that the restore wizard is asking.
As you can't remember or lost the password, you need to reset the password.
Download this softwware called "Elcomsoft System Recovery Professional"
It can easily reset you password or even let you know your forgotten password within a minute.
Here is the download link
http://www.megaupload.com/?d=HUVCQWFK
Just type the security alphabets and click download.
It's a rar file,you need winrar to extract it.
and the password for that file is  : www.fullandfree.info
Extract the ISO image and burn it a CD.
Boot the system using that CD (Set your BIOS to boot from CD-ROM).
you can easily recovered the password or reset it.
Note down the password and carry on with your restoration.
If you want help on how to do Image restore,then follow the link below
http://www.insidemylaptop.com/factory-image-restore-dell-laptop-with-windows-vista/
Rate this solution.
3helpful
Emachine laptop D620: reset password after system restored
Insert OS cd in drive and start reinstalling by selecting repair mode now once all files are loaded system will reboot when you see the Installing Devices progress bar, press SHIFT + F10
this will give you access to your account also you can reset all passwords
Now restart lappy and let the system boot normally without OS cd in drive
now you will come to old screen and previously configured desktop with all intact aplication and icons on desktop and it will no more ask you for password till you set a new one
Thanks and regards
Kindly rate this solution
3answers
Acer 3089
hmm which password ??? is it the bios password or the windows password.. Any way I will give you solutions for both
THE BIOS PASSWORD
1.) unplug the computer system
2.) remove the side panel
now you have two option
OPTION 1
3.) locate the jumper jp1 or jcmos1 you can use your manual for a refrence its a 3 pin jumper located cloase to the battery
4.) the jumper is currently on 1 and 2 , set it to 2 and 3 wait a few seconds and set it back to 1 and 2
5.) THATS IT BIOS PASSWORD RESET
6.) boot system enter setup and load optamised defaults.
7. save and exit setup
OPTION 2
incase you cant find the jumper
3.)remove memory
4.)remove the battery
5.)press the power button 5 times to empty any charged capicators
6.)replace battery and memory
7.)boot ystem enter bios load optimised defaults , save and exit
TO RESET WINDOWS PASSWORD
1.) dowload hirens boot cd from here
www.phazeddl.com
you will need to search hirens when you go to the site
2.)burn off cd
3.) boot from cd
4.) use the on screen menu to fine windows password reset tools,
5.) choose the appiorate one and follow instructions to change or reset password..
THATS IT WINDOWS PASSWORD RESET..
let me know if you need any more help good luck
Grand Canyon Tech
Grand Canyon Tech
