Question about Car Audio & Video
My Phillips radio displays ERR CODE, how do I get rid of that and unblock it
  • 4,862 Answers
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself
This make take an hour or more
Make sure you have the correct code
Posted on Apr 02, 2011
Testimonial: "THANK YOU regforge, that worked perfectly. Thanks Again"
    Problem Solver:
  • 13 Answers
Vwz6z1s1372274 philips alpha pleas code
Posted on Apr 03, 2011
  • jamesfami174 Apr 04, 2011
    Already sorted thanks !
How to use radio controls after code set
if you have the code (you say you do) turn radio on, push the code, radio should come on automatically (here is my code it will work on yours 2145) so 1 turn radio on. err code will show dont worry about it. 2. punch in 4 digit code.3. complete code will flash 3 times. 4. radio will be fully functional, use as normal. if you enter code wrong an Err will display for a few sec. COde will then display. repeat procedure 1-3.
Apr 20, 2013 | 2000 Daewoo Nubira
I have lost my radio code
As a security measure, any time the battery is disconnected, the radio is Locked Out, and will not function until the security code is entered on the radio itself. Furthermore, after 3 tries, it wont even accept the code on the radio display, showing the ERR condition. Check for a sticker with the radio code inside the glove box. Some dealers fixed a second sticker in the owners manual. If not available, get the code from a Honda dealer, and be prepared to show VIN number, and proof of vehicle ownership.When you get hold of the code, disconnect the battery for 15 min. This will erase the ERR condition, and allow you to introduce the reactivation code.
Jul 15, 2011 | 1998 Honda Accord
I want to Get rid of the 'Err' message on the radio so I can key in the security code to get the radio working again.
Leave SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself
Mar 17, 2011 | Car Audio & Video
I have a mazda 323 with a phillips stereo cassette deck and need the code has it has err on it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
Aug 12, 2010 | Philips Car Audio & Video
Iocked out of radio
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
If it says LOCK13 then too many wrong codes have been entered
Jun 09, 2010 | Mac-Audio Dynamic 2.13 Car Component...
Error message on nissan xtrail car radio wont return to code in put message been 3 days since battery disconected tryed disconnect again no change
If you have the anti-theft code (it's like a business card attached were you find the code and direction) just follow the directions to enter the code but if you don’t have it, here is a link to get it
http://www.radio-code.com/?gclid=CLCh1em-jZ8CFZAN5Qod-zvRMQ
Jan 05, 2010 | Car Audio & Video
What are the codes for chevy anti-theft radio
If the radio display reads "code" then simply use theradio preset buttons, enter the code in the correct order, and the radio will unlock. If, however, the radio reads "Err" or "Code Err" It's likely that someone has made several attempts to unlock the radio using incorrect codes. In that case you will need to disconnect and reconnect the negative battery cable. This will reset the radio and allow you to enter your code. If you lost the code, you may retrieve it from https://radio-navicode.honda.com/
The code they gave me was 2246, but I had to add an 1 at the end of it to get it to work, so the end of it was 24461. Yours will be different.
Oct 06, 2009 | 2002 Chevrolet TrailBlazer
Err code displays when i put a cd into my radio.
the cd player only is the problem even though it is all in one unit the radio will still play. tr a different disk if no luck then unfortunatley the problem is in the radio itself. you can buy a nice after market radio for alot less money. keep me posted thanks
Jan 31, 2009 | 2003 Chevrolet Malibu
TOC ERR
this is caused from the pickup needing to be cleaned(lazer) remove deck remove small phillips screw on top plate use a damp q-tip (alcohal) gently rub the lazer top with the q-tip allow to dry aprox 10min reasemble and enjoy. Also make sure u don't need a security code for your radio before u unhook the power plug!!!!
May 16, 2008 | Kenwood KDC-MP228 CD Player
How can I reprogram Nissan pulsar car radio a battery change which has deleted memory? panel shows error message only ERR.
You will need to turn the ignition on (do not start the car) turn on the radio and leave it on for anywhere between 1 - 3hrs untill it prompts you for a code.
There is a internal timer which adds time depending on how many times the code is entered wrongly.
Do not start the car, or turn off the ignition or radio during the 1 - 3 hr period.
Hope this helps.
Thank you
Adam
Apr 27, 2008 | Audio Players & Recorders
Car Audio & Video Logo
153 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
