Question about Definitive BP7006 Main / Stereo Speaker
The sub on the left speaker don t play and the light went off but the mid and tweeter have sound coming out
    Problem Solver:
  • 9 Answers
The amplifier that drives the built in subwoofer has stopped working. The first thing to do is check that the power cord is plugged in to a live power outlet. Next, replace the fuse which you'll find on the large black metal plate on the back of the speaker. Use only the size and type fuse specified. If that does not work contact Definitive customer service at (800) 228-7148.
Posted on Apr 02, 2011
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
Windows vista wont let me select subwoofer
Try Control Panel > Sound and Audio Devices > Volume > Speaker Settings > Advance. Choose Speaker setup.
Aug 27, 2012 | Gateway GMAX 2100 Computer Speakers
I put a sub in my 2002 Altima but when I turn it up the bass cracks on the door speakers??? What do I do to get all the bass on the sub
Hi Ethan,
What you're looking for is called a "crossover". A crossover is an electronic filter for an audio or speaker circuit. In an audio circuit, a crossover is used to prevent or pass certain frequencies or a range of frequencies from passing through it. Since your sub will reproduce the bass or low frequencies, you don't want other speakers to reproduce them. A band pass filter on your door speakers will do this for you. A band pass filter passes only a range or "band" of frequencies and blocks those that are above and below the range or band of frequencies selected. Installing a band pass filter will prevent the very high & very low frequencies from getting to the door /dash speakers. Likewise, you should consider connecting a low pass filter to your subs, too. The low pass filters work a little differently from of the way band pass filters work - they only allow low frequencies to get to the sub - blocking all the other higher frequencies (your other speakers are better suited to reproduce those). Lastly, you would install a high pass filters on tweeters. Tweeters are designed to reproduce only the high frequencies - sending mid and low frequencies to them is wasting power and can cause damage to them.
You purchase the filters for specific crossover points (the block / unblocked point) as determined by the individual speakers. If a sub has a frequency response of 20Hz - 100Hz, a low pass filter of 100Hz would be ideal. Remaining filters would need to begin at 100Hz - assuming the mid-range speakers have a frequency response beginning at 100Hz. A band pass filter of 100Hz - 3KHz would fit the bill nicely if the mid-range speakers go up to 3Khz Match the high end of the band pass to the high end of the frequency response of the mid-range speakers. Next, a high pass filter at 3KHz would allow only the high frequencies to your tweeters. Basically, you want to have the entire audible range 20Hz - 20KHz covered by the speakers and have the crossover points that match the frequency response ranges of the speakers.
I hope this helps & good luck!
Apr 12, 2012 | Pioneer Car Audio & Video
Just the tweeter is playing and not the mid
It's a midrange component speaker. Possibly your midrange speaker is blown. Check your wiring.
You hear the tweeters i am assuming because the vehicle has tweeter component speakers that are separate from the midrange and low components.
Apr 19, 2010 | VIFA P17WJ-00-08 Car Mid-Range Speaker
I Have a Gem Sound EVA3955 amp an TR-150 subs sub stop wroking
Yes and Yes. If bypassing that noise filter, has no effect your subs could have blown.
Jan 05, 2010 | Car Audio & Video
I have Exa 3955 amp and TR-150 subs mid range and tweeter works subwoofers stop playing both
Open the sub box, and check to make sure the sub wires didn't become disconnected. You should need only a screwdriver.
Jan 05, 2010 | Gem Sound Car Audio & Video
Subwoofers not working but tweeter and mid-range do
Try jumping the sub by connecting the speaker cable directly to the speaker , not just the connector on the back
May 25, 2009 | Kenwood Radio Communications
Bostom tweeter cutting out
get a new tweeter. really, if its starting to cut out, or static, then its prabably old and need a new 1
hope i was help :)
Apr 28, 2009 | Car Audio & Video
Subwoofers
they sound like there blown to me
Jul 09, 2008 | Car Audio & Video
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
Definitive BP7006 Main / Stereo Speaker Logo
449 people viewed this question
Top Definitive Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob
Rob
Are you a Definitive Audio Player and Recorder Expert? Answer questions, earn points and help others
