Question about Maytag Portable Air Conditioner M6P09S2A
I have a maytag nmpeb08f2a portable ac, just started it up for the season. cleaned the filters and coils by wiping down . I also emptied bottom resevior. Im not getting cold air when on cool setting, tried lowering temp all the way. when i turn it on it will be cold for a short time, doesnt fell cold like befor, the temp will go down maybe 1 degree then, no more cool air. can i add refrigerant to this unit?
    Brigadier General:
  • 4,736 Answers
Frank, refrigerant is what it needs, but it should be done by a pro. Unless you have experience with this sort of thing, it's not a DIY project,
Posted on Apr 02, 2011
Maytag com manual
Like most modern consumer products manuals, the answer to getting one is dead simple. Open Google, type in "User Manual, Maytag portable air conditioner Model NMPEB08F2A": and just like magic Google gives you back the following data response:: "http://usermanualnmpeb08f2a.yolasite.com/"
Just click on it and a seven..jpg icons appear on your computer screen, one each for a color photo of the seven pages of your manual for the Maytag portable air conditioner Model NMPEB08F2A
Modern computer information technology has made getting your hands on information and documentation extremely fast and simple.
Sep 06, 2014 | NMB Technologies Computers & Internet
@gmail.comshould i need to put more freon in this air conditioner?
The only time you have to add freon is if you have a leak in the refrigeration system. Check and make sure all your coils are clean and the filter is clean. If its a cleaning issue these things will seem like its low on freon but is not just needs some love.let me know ok
Jul 23, 2011 | Maytag NMPEB08F2A Air Conditioner
Need part number a5815-090-h-bs this is the window adaptor for the hose connection. AC portable 9000 btu. lost the window plate/adaptor. need to replace it.
did u find the adaper for the Maytag M6PO9S2A? I found one but not sure if its the right one as I also have the same portable air conditioner
Jul 07, 2011 | Maytag NMPEB08F2A Air Conditioner
UNIT WILL NOT COOL. FAN AND HUMIDIFIER WORK. THIS IS ONLY THE SECOND SEASON USED AND THE UNIT HAS NEVER BEEN SITTING UP AND NEVER LAID DOWN OR TURNED UP SIDE DOWN. WHAT IS THE PROBLEM?
A portable air conditioner may not cool for several reasons. Check the filter by removing the unit's grill and clean the filter.
Also check for clogs in the evaporator or condenser coils by light vacuuming. Make sure the evaporator isn't frosted over, but if it is, allow it to defrost and normal operation should resume.
Lastly, ensure the ambient temperature is lower than your AC's set temperature, as this can prevent cooling. However, if all of these steps fail to resolve your problem, the compressor may be malfunctioning, and in this case, the compressor needs to be replaced or repaired.
In summary, if the air won't cool, remove the grill and clean the filter. Clean out any clogs in the evaporator or condenser coils by vacuuming them and scrubbing them lightly with an old toothbrush. And since fan is working, you compressor might be defective.
I hope the above information is clear.
Regards.
Jun 24, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
My Maytag portable A/C will blow cold air for one cycle, then after about five minutes it just blows room temp air and never gets cold again. If I turn power off then back on it does the same thing over...
Cleaned the filter screen or the coils? There are two coils. The evaporator coil and the condensor. There is the "filter screen" in which you can clean which is located in the back top portion of the panel that is easily accessible. However to clean the coils you need to remove ALL the back screws from the back cover and remove the entire back panel. There you will see both coils. From your statement it sounds like there isn't sufficient airflow over your coils and the freon cannot release its cooling effect into the hot air thus it tends to ice up on the coils. You need to wash out all the lint dust from both coils. You can do this with with air conditioning coil cleaner or for starters use a stiff paint brush and vaccuum. Clean as much debris off as you can, then run the unit. It should last longer than your previous five minutes. If it doesn't work then your in trouble. There is a metering device called a TXV or expansion valve that may have failed causing the freon not to flow freely thoughout your system. However it is a rare occassion that it fails so it should be that the coils are dirty. GOOD LUCK
Aug 25, 2010 | Maytag NMPEB08F2A Air Conditioner
I have a used Maytag portable a/c, model #SMPEB08F2A. It has a little hole at the bottom left in the back which may be a drain but I don't know how to drain the water out. How and where do you drain the...
the drain is generally the midway in the back below the coil, there may or may no be an internal hose connected from the blower housing or evaporator coil housing, they are drained by gravity and the unit pitched to the outside should accomplish that if the drainage path is not clogged
Jul 14, 2009 | Maytag NMPEB08F2A Air Conditioner
Maytag Air Conditioner NMPEB08F2A
the blower is not coming on chech for solutions in manual
May 31, 2009 | Maytag NMPEB08F2A Air Conditioner
IF there is a lot of water, the float switch probably tripped. Happened to me, the water motor failed. When this happens there is no water blown up into the evaporator coils and it just accumulates.. and trips the float sensor. 2 problems with replacing the water motor. I can't get the part easily, and you have to remove all the plastic shrouding and drop the bottom out to get to it. (Steve)
Aug 02, 2007 | Maytag NMPEB08F2A Air Conditioner
Maytag NMPEB08F2A Portable Air Conditioner
I have the same problem w/ a window unit - fedders unit under the Maytag brand. No idea how to fix it, but would be great to get some info on this.
Jul 15, 2007 | Maytag NMPEB08F2A Air Conditioner
Lack of cooling
Check for blocked filters or coils, both on the hot side & the cool side. It is possible that either is blocked by airbourne dust or debris. This is common in areas with lots of poplar trees.
Jul 05, 2007 | Maytag NMPEB08F2A Air Conditioner
Heating & Cooling Logo
268 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
