Question about TP-LINK TPLink TDW8950ND 150Mbps Wireless Lite N ADSL2+ Modem Router IEEE 80211 bgn 4x LAN Ports
TD-W8950ND: how do I adjust SNR. I have set the debug flag. Can't get it to connect to the dmt version 8.07 tool either. http://translate.google.com.au/translate?hl=en&sl=de&u=http://dmt.mhilfe.de/&ei=_YsgTZK7KZGgvQPv74GZDg&sa=X&oi=translate&ct=result&resnum=1&ved=0CBwQ7gEwAA&prev=/search%3Fq%3Ddmt%2Btool%26hl%3Den%26client%3Dfirefox-a%26hs%3Dw44%26sa%3DG%26rls%3Dorg.mozilla:en-US:official%26prmd%3Divns
2 Suggested Answers
  • 98 Answers
SOURCE: My tp-link TD-W8950ND 150Mbps Wireless Lite
this is because your modem is out dated your better off getting a new one
Posted on Mar 20, 2011
Jit debugger error
jrotten65,
This error only pertains to Microsoft Visual Studio. Depending on which version of the software you are using, follow the links below.
Try updating to the newest release of Visual Studio
http://www.microsoft.com/express/
or use the Debugging Tools for Windows as an alternative
http://msdn.microsoft.com/en-us/windows/hardware/gg463009.aspx
The Registry key HKLM\SOFTWARE\Microsoft\.NETFramework\DbgJITDebugLaunchSetting is set to 0x00000010 when JIT debugging is enabled.
I hope this helps.
Nov 04, 2012 | Dell Computers & Internet
When trying to download from Ipod to PC, get dialog box error message that says: "Object reference not set to an instance of and object. Then "mhyp, 68017"
This is because you are not copying it correctly,
Disconnect the IPOD and connect again and open ITUNES to copy the songs.
Make sure you are copying the songs from the IPOD to PC.
Jan 20, 2011 | Cosmi iMusic Tools Essentials
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
May 29, 2010 | Dell Studio XPS 16 Notebook
Debug assertion failed
okay open internet explorer and then click tools>internet options. then go to the advanced tab and make sure debugging is turned off
Apr 27, 2008 | Compaq Presario 5000 PC Desktop
Netopia losses connection to internet and to server and vp phones
The Netopia Is a business-class router. Not clear from you question are you running Small Business Server or Windows Server 2003? If its the former, it has a wizard that will configure your LAN & the Netopia.
You can configure the Local IPs on the Netopia in the DHCP settings in expert mode.
The VP (VOIP?) phones are acting as a DHCP server & re-configure the network to their defaults.
Any 1/2 decent IT person (witth some real qualifications) could figure straiten this out...beware of "Techs"
Mar 04, 2008 | Netopia (3347NWG-VGX) Wireless Router...
What is the SNR
The STAC9221 is deigned for media-centric systems such as Media Center PCs, Game Enthusiast PCs, and new classes of devices aimed to distribute music and video around the home. The STAC9221 sets the standard for high performance by providing 8-channels of true 24-bit audio with a 105dB SNRSee signal-to-noise ratio.
..... Click the link for more information.
(Signal-to-Noise Ratio). This level of performance enables theater quality 7.1 surround sound to PCs and PC-like devices that continue to move into the living room alongside or in place of traditional consumer electronics gear. The STAC9221 incorporates an ADAT(R) Lightpipe interface allowing connectivity to professional audio equipment. The STAC9220 provides 95dB SNR performance setting the standard for the high volume, mainstream desktop PC and high end notebook PCs
Hope that helps.
For more see;
http://www.thefreelibrary.com/SigmaTel+Announces+the+STAC9220+and+STAC9221+8-Channel+High...-a0126662778
Jan 15, 2008 | Computers & Internet
PC PROBLEM
Reinstall the explorer and try internet explorer 7.
Aug 27, 2007 | Microsoft Windows 95 NT 4.0 Workstation
TP-LINK TPLink TDW8950ND 150Mbps Wireless Lite N ADSL2+ Modem Router IEEE 80211 bgn 4x LAN Ports Logo
247 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
John Anderson
John Anderson
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
