Question about Zanussi ZWF1440 Front Load Washer
Zanussi FJ1214 I have what has been up to now a very good and reliable machine. The fast spin does not seem to be working although the drum is turning around fine. It seems to get up to a low speed for the spin but does not speed up. Is there a fuse or a relay or a microswitch or some such other little gadget that might be needed to make a circuit before the machine goes onto fast spin? I am not sure about the rinse but this might be playing up a bit as well. The rest of the wash cycle works fine. Thanks for any help or pointers. Adrian
    Scholar:
  • 97 Answers
Hiya
the first thing i would check is the motor brushes, as this can be a sign that they are worn down and in need of replacing. the easiest way to check is :-
1, remove the plug from the mains
2, tilt the machine back, making sure it wont fall on top of you.
3, looking under the machine the motor will be directly in front of you and the brushes will be on either side of it.
4, you will need a 5.5mm socket and a small ratchet to remove the screws.( you will only need to remove one brush as they wear evenly, if they are worn then BOTH will have to be replaced)
5, the brushes will just pull away from the motor, anything less than 10mm of carbon i would replace.
NOTE
on the brushes you will notice two small lugs, these are to ensure the brushes are correctly lined up, make sure when refitting that these are locked into their correct holes on the motor.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Posted on Aug 05, 2008
Zanussi FJ1214 Washing Machine won't agitate but spins
Sounds like gearbox or check if a belt has came off or slipping underneath.
Nov 01, 2014 | Zanussi Washing Machines
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
Zanussi fs1455w not spinning fast under load. Without anything in the drum it spins fine??? Tried all speeds with the same result. Any ideas???
May be not pumping efficently. when the spin starts the initial rush of water floods into the drum from the clothes a build up of water under the drum causes a braking action on the drum and slow spin speed.. look for partial blockage in pump chamber hoses or under sink if a spigot connection. probably not the belt as it would throw off a loose belt. Check it anyway. if non of these check carbon brushes they may on the verge of failure.
Jul 23, 2010 | Zanussi FS1455W Front Load Washer
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Thanks.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
Noisy spin cycle
Hello your problem is the the drum.. To be more precise its the drum bearing.. theses wear out and can be replaced on the zanussi id suggest that you get an engineer out.. its about £100 to get it done
Dec 15, 2007 | Zanussi F1045W Front Load Washer
Slow spin
Make sure filter is free,we like to rated good or bad, thank you eire
Dec 03, 2007 | Zanussi FJD1666W Front Load Washer
Zanussi Aquacycle 1000 f1045 spin dry fault
test the machine empty without clothes in it, if all is well then i think your problem may be the motor carbons, take them off and check for damage, make sure one of them has not spit down the middle, also look at the armature for signs of sparking,a worn armature or carbons will work fine at slow speeds
you haven't mentioned the carbons, its trying to spin so may not be the pcb
Oct 14, 2007 | Zanussi FJD1666W Front Load Washer
Drum is not moving
It sounds like the drum drive is broken ... could be a belt at the back of the machine or it could be gear driven ... most likley a belt... take off cover on back of machine to see if the belt is broken and replace if necessary. Also could be pump but that is probably the last thing to go wrong pumps rarely ever fail.
Apr 28, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Drum noisy when spinning
main wash bearing fail parts for this £48 if you are mechanicaly minded then its a 3hr job if you have all the tools appliance doctor
Jan 28, 2007 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi ZWF1440 Front Load Washer Logo
167 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
