Question about Video Game Consoles & Games
How do you coonneect a ps3 to a phillips tv using a HDMI cable i tried and it will not have any picture and i forgot the make of the tv so plz help
    President:
  • 1,139 Answers
Please try the following to reset your display so it will work with your TV -
http://www.fixya.com/support/r6784945-playstation_3_no_display
Thank you for using FixYa
Posted on Apr 02, 2011
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
Ps3 hdmi format not supported
Tries something else with a HMDI with the Phillip Tv.Like DVD player With HDMI see if it work with the TV.Narrow it down might have to use all the HMDIs inputs use.See if it all works.
Might just have one or two HMDIs shorted out put.
Sep 04, 2009 | Televison & Video
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Cannot get my HDMI cable linked from my ps3 2 my hd tv
Try video settings on the playstation 3. Adjust it to reflect hdmi.
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
Install ps3 on avr-4306
PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Denon AVR-4306 Receiver
PS3 - green Bar when playing blue ray on my 50" Phillips Plasma
Green bar or border is due to wrong AV Setting. To resolve this just insert the Blue-Ray DVD and begin to play. Press the Triangle button and select "AV Setting", in AV Setting change Video Output to RGB.
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
PS3 HDMI PROBLEM WITH SOUND
I am pretty sure you need to have an Optical cable running from Your PS3 to your sound system...if you have one...
So basically you will have a HDMI cable running from your PS3 into your TV, another HDMI cable running from your TV into your sound system, then an optical cable running from the PS3 to the Sound system. I sadly own a HDDVD sound system but the optical cable tells it to accept the Blu Ray content.....
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
18 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
