Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Internet connection My internet connection works fine when i connect me laptop directly into the modem but when i use the router the connection keeps going sporadically. This happens both with my laptop that is connected wirelessly and my xbox that is wired to the router. Any ideas?
    Novelist:
  • 173 Answers
Try to update the router's firmware to the latest one, if conection is still dropping try lowering the MTU size(by default its set to auto) to 1492, 1480, 1472, 1450 check which MTU size will make you connection stable.
Posted on Aug 05, 2008
SOURCE:
L cannot get internet when connected to my router, but l get internet when connected to modem directly.
Your ISP allows only one device to connect to their network.
When you change devices (router versus computer),
you need to power-off the ISP's modem, and unplug it.
Connect the router to the modem, and connect your computer to your router.
Plug the modem back in, and the modem will "forget" what device was previously connected.
Feb 18, 2015 | BestPriceCables TP-LINK Ultimate 300Mbps...
Hello, I have Dell Inspiron 1525 Laptop and wireless Internet doesn't connect. I see the wifi light is ON and I see in Internet connection it shows my profile as connected. But if i browse internet does...
Please connect your computer directly to your DSL / Cable modem and check if your internet is working fine, if not turn off your modem and restart after a minute or two.
Now check again if the internet is working by directly connecting your laptop to your modem. if it is not working, contact ISP. if it is working, turn on your router and check if your wireless connection is working.
If you wireless connection is still not working, please check if you have plugged the modem to the internet / WAN port behind your router.
Also try logging to your router page (refer to manual for procedure) and try changing the wireless channel.
Dec 24, 2010 | Dell Inspiron 1525 Laptop
Since getting a new Dell laptop and Linksys E1000 (also have HP desktop), my internet connection keeps dropping (no problems ever before)- sometimes I can stay online for 2-3 hours or it can go in 15...
we need to first figure out whether it the modem or the router which is dropping the connection.
Please connect one of your computer directly to the modem, by pass the router and access the internet. If the connection drops then its the modem which is dropping the connection and you need to contact your isp to check it.
If the internet works fine directly with the modem then its your router which is dropping the connection. To fix the router we can upgrade it firmware.
To upgrade the firmware please visit the link below;
http://homesupport.cisco.com/en-us/wireless/linksys/E1000
Note; If you are not comfortable upgrade the firmware then don’t do it. If not done properly then it can damage your router.
Rashish
Aug 16, 2010 | Linksys Wireless-G WRT54G Router
I have a linksys wireless g router that worked fine until yesterday. Now it won't connect to the internet. I have a desktop wired to the router and a laptop used wireless.
Check if you can connect to the internet when hooked directly to the modem. If your connection works fine through the modem, then your router needs to be reconfigured.
May 13, 2010 | Linksys Wireless-G WRT54G Router
I just starting using this wireless router and when I set it up the router software keeps saying I don't have a connection to the internet but I'm on the internet on that computer right now. ...
Make sure that there is not direct connection between your desktop and modem ( USB ). If there is any USB connection from the modem to the computer then it will go on linee but the router will not be on line.
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Apr 30, 2010 | Linksys Wireless-G WRT54G Router
N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
www.belkin.com/support
Regards,
Aysaam
Apr 13, 2010 | Belkin N1 Vision Router
Router doesnt connect to internet
This sounds like a problem with your DSL modem, not the router. Try unplugging both devices and wait about 10 seconds. Plug in the modem first and wait about 30 seconds (at this point the Internet light should be on). Now plug in the router and wait another 30 seconds. This problem is normally due to the modem not getting sync. I would try plugging your laptop directly into modem if this doesn't work to see if you then have Internet. If not call your ISP.
Feb 14, 2009 | Linksys Wireless-G WRT54G Router
Internet connection between linksys router
May be your router internet settings has been wrong. you must reset the router settings by clicking the router reset button. Pls locate the button and then put the internet cable into router internet port.
Jan 03, 2009 | Linksys Wireless-G WRT54GS Router...
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connecting a modem and router to my desktop
When you connect all the devices make sure you reset them all after plugging them together. Also use a different ethernet cord and make sure your plugging the Modem into the WAN port on the router. If your still having same problem just let me know.
May 08, 2008 | Linksys Wireless-G WRT54GS Router...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
69 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
