Question about Wharfedale SP-87 Speaker
Can you Bi-Amp these speakers (SP-87) as I have lost my paperwork on them?
    Brigadier General:
  • 8,546 Answers
Can you SEE the rear of them? Those jumpers are for disconnecting the speakers so you CAN bi-wire them.
http://sacramento.craigslist.org/ele/2288608008.html
Why, I'll never understand.
Posted on Apr 02, 2011
Hi,i hear alot about bi wireing could someone explain what it actually is used for and what's it meant to do could I'm thinking bout trying it on my speakers?
It's a big job, but the results are great. Bi amp-ing is where the tweeters and mid range speakers are separated and connected to separate amplifiers. You'll need to have the correct gear before messing inside your speakers. You'll need to have another amplifier. Not knowing what amp you have now, getting a stereo signal into the second amp may be a problem since you'll need a line level signal into the second amp. An external crossover is best. Technically, you could use the ones in the speakers, since you'll be removing them anyway. Now for the speaker mods: On the panel where the posts for the speaker wires are you'll need to install another set of binding posts. We're assuming you have separate subs. Open the speakers and remove the cross over. The wires from the original posts should now connect to the mid range speaker. Add wires from the second set of posts and wire it to the tweeters. Now connect the output of the amp to the removed cross over and wire the mid range out on the cross over to the posts that connect to the mid range speaker. Do the same for the tweeters.If you have three way speakers, you'll have to run a 3rd set of wires from the crossover to the woofers in the cabinet using another set of binding posts. Controlling the volume on the second amp will be difficult since you'll have to adjust it manually. Remote control volume level will be lost on the second amp.
Aug 08, 2015 | Audio Players & Recorders
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
I have Xavian xn125 speakers. How do I connect them in a bi-wired or bi-amp
Bi-wiring basically works wtih one amp. You need a crossover network and a signal doubler to use two amps (bi-amping). There are many diffent ways to bi-amp (horizontal, vertical,...) This link: - -http://www.soundstage.com/synergize/synergize031998.htm-- explains them all. Bi amping is usually not worth the extra price and complexity when used on smaller speakers.
May 13, 2014 | Audio Players & Recorders
On the connection for my Boston Vr2 Floor Speakers there are 4 connections which are connected vertically with a brass plate which is approx 1/2 " wide. I have lost one and the speaker does not seem
You can use a piece of speaker wire to replace the missing bar. those speakers are designed to be used with the bars in place for normal use. they can be removed if you are bi-amp/bi-wireing them.
Jan 14, 2013 | Boston Acoustics Audio Players & Recorders
Peavey SP 5 speaker has stopped working
Check the crossover network for cracked solder joints, specially pay attention to the female1/4 jacks as they are very tricky since they are switches also, you might be surprised...
Apr 29, 2012 | Peavey SP 5 Speaker PA Passive
Speakers to amp
With the CLS-215 speakers, you can Bi-Amp or Bi-Wire them.
Here is how to Bi-Wire and Bi-Amp Speakers:
http://www.oregondv.com/Audio_FAQ_Bi-Wire_Bi-amp%20.htm
Jul 13, 2010 | Cerwin Vega CLS-215 Main / Stereo Speaker
Bi-Amping my speakers with HTR-5850
You can at a minimum, bi-wire your speakers by wiring the speakers with the A and B speaker outputs. The A speaker outputs end up running the tweeters and the B will end up powering the woofers.
Dec 30, 2008 | Yamaha HTR-5850 Receiver
Bi-amp
After examining a picture of a 5802 ( I have been servicing adcom for over 20 years ), these are not bi amp posts, but bi wire posts.
Bi-amp means that 2 amps are being used, one for highs, one for lows. This means that you have no crossovers in the speakers, instead, you have an electronic crossover between the amps and the pre-amp. The highs and lows are separated in the electronic crossover. One amp handles the lows, one handles the highs.
Bi-wire means that you have the crossovers still inside the speakers. The amp handles the full range of music ( highs-mids-lows ). Different kinds of speaker wire produce different results. If you have bi-Wire terminals on your speaker, they come with shorting wires, that tie the tweeter + to the woofer + on the back of the speaker, and the tweeter - to the woofer - . When the shorting wires are removed completely, you have now electrically separated the tweeter and woofer from each other, while maintinaing the crossovers ( inside the speaker ) for each.When this is done, you can now bi-wire the speakers and amp, and use different kinds of wire for the lower frequencies and the upper frequencies, depending on your ears ( everyone hears a little differently, thats why there are so may makers of components, and wire ).
Why do we have crossovers?.....the tweeter voice coils ( the things that make the sound ) are made of hair thin wire. This wire cannot handle much power and if you were to put bass in to a tweeter, you would burn the tweeter out almost instantly. A tweeter is a very light, fast moving device which can react very quickly to high frequency sounds ( symbols, triangles, guitar strings....). Woofers are more rugged. They have voice coils made of heavier wire and are designed for larger movements that Bass demands. Subsequently, woofers aren't very good for high frequencies because they are slower devices.
So what do we do ?.....Keep the lows away from the tweter and the highs away from the woofer.....thats the job of the crossover.
In the event that your speaker has the crossover OUTSIDE the speaker box, you should check ( as always ) with the manufacturer of the speaker to see how it can be changed to suit your needs. Remember to always read and follow your owners manual. Good luck....Rob
Feb 22, 2008 | Audio Players & Recorders
Peavey SP 4
I would like to understand you problem better,
Are you trying to repair the input to the speaker from the amp???
Please elborate thanks
Sep 11, 2007 | Peavey CH1 Speaker
87 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
