How can i use the scanner function? - Computers & Internet
  • 3 Answers
My favorite software to use with Windows for scanning is called FreeKapture 2.0. You can search for it on Google or download it from the following site: http://www.freewarefiles.com/FreeKapture_program_32165.html. You can find a manual for it online. It is a simple utility. You install it, attach a scanner to your computer, open the software, click "Scan", and then tell it to save it as the file you prefer.
Windows also has built in program called "Fax and Scan" which can be found under Start Menu>Programs>Accessories.
Posted on Apr 02, 2011
How do I bring the menu up on the BCD396xt scanner screen? Pushing the menu button on the side does not do it?
Each key has two functions, normal or function mode. If you press the function an menu key together you can get in the menu. Sometimes you must hold the keys for 2 seconds.
Jan 19, 2015 | Uniden BCD396T Handheld Scanner
Scanner function does not appear to work. All
i would say possibly you are missing out on something..because if the other functions particularly photocopying are working then this should work..as in if the photocopying function works then the scanner is ok cause basically in photocopying the machine scans then prints... perhaps check whether you are correctly following procedure to scan..most hp all in ones have a button on them that you press and it automatically initiates scanning and simultaneously the software on the pc is initiated..try this,if not then try reinstalling the hp software..hope this helps..regards
Jun 04, 2010 | HP Photosmart 2575 All-In-One Printer,...
How to tell what the buttons do?
The HOLD key lets you freeze the scanner on an active channel. For instance, if the scanner stops on channel 3, and there's a lot of action there. you can press HOLD to lock the scanner on that channel until you press the SCAN key. Repeatedly pressing the HOLD key will manually advance the selected channel.
SCAN releases a HOLD asnd will also take the unit out of PROGRAM or SEARCH modes and start it scanning the frequencies that you've programmed.
FUNCTION selects the secondary (lower) function of a key. For example, pressing FUNCTION and then the E (ENTER) key will switch the scanner to Pgm (Programming) mode - which lets you enter and store frequencies into the unit's memory so that you can scan them later.
All keyboard functions are explained in detail in the scanner operating manual, which you can download/print here:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, along with a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Apr 11, 2010 | Uniden Nascar BC-92T Scanner
Will not work with Vista operation system
Correct. There is no easy solution for this issue. Several of the "older" scanners are no longer supported through the Vista operating system. Why not purchase a new multi function printer, scanner, fax and copier unit.. you will not locate vista drivers either online or from the manufacturer and without them, the scanner will not function. Alternatively, you could also roll back or re-install Windows XP operating system..
Nov 02, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
I am using windows xp and I am having problems scanning using HP officejet L7590. I can print with no problems
http://h10010.www1.hp.com/wwpc/pscmisc/vac/us/product_pdfs/3643611.pdf
this is an user manual ..complete edition ...save it ...and read it well .cause if you can print it means that isnt a driver problem ...but just your skils with it ...I hope this will in-light ya ...
Jul 18, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
Nikon LS-2000 scanner gives error 0x04620000
Stepper Motor Failures
Within the first 6 months of purchase I had to return the scanner twice to replace the stepper motor. The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
service required to fix stepper motor
Jan 07, 2009 | Nikon LS 2000 Film Scanner
Copy function
well you gotta provide the details in scanners configuration where you want the scanner to copy your Documents to .i.e. whether you want it to scan and store it as a image or open it with some Application or you want it to print just assign any one task with proper configuration it will definately work.
Thanks
Nov 17, 2007 | Canon CanoScan LiDE 30 Flatbed Scanner
Cannon scanner D1250U2F and Hp photosmart printer 8250
This is a compatibility issue between the Copy function of Toolbox and the specific HP printer driver. The only work-around would be to scan your image and save it, then print it from another application. One other possibility would be to get Toolbox version 2.2.x from the N650U scanner download page. This version will be limited in functionality, but COPY button should function as expected.
Apr 28, 2007 | Canon CanoScan D1250U2 Flatbed Scanner
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
