HELLO SIR I HAVE ELCOT 14 TV NO SOUND FROM TV I REPLACE AUDIO IC UTC2003 AFTER SOME TIME ONCE AGAIN SAME PROBLEM PLEASE GIVE ME ADVICE
My 14" TV have a pblm of non sound before it comes slowly but now completly dead in sound
no more sounds will come
how to i solve this??/
can any one help me???
Posted on Jul 11, 2011
Is audio output (from main ic) is imputed in utc2003 audio amplifier ic?
Is the UTC2003 IC your main IC?
You can't find inputs or output of this IC?
This IC is power Operational Amplifier simply. It has TWO inputs noninverted = pin 1 and inverted = pin 2 and ONE output = pin 4. Pin 3 is ground and pin 5 is supply voltage. It's simple as the rake! What is your problem? Sorry for my rusty English...
Feb 03, 2015 | Audio Players & Recorders
Is audio output from main ic input to utc2003 audio amplifier ic?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 03, 2015 | Televison & Video
Elcot tv model 27404 sound dead
elcot tv model 27404 sound dead.please give me solution
Regards,
R.kannnan
May 07, 2013 | Televison & Video
I cannot get any audio from my tv / cable at all. I hae unplugged everything and reconnected. I can see the volume control on the screen and can see it go up and down from the tv and from the cable...
Hello
Either your tVs speaker of its audio output IC has damaged. Check the TV by onnecting its audio out jack to any other audio source, like amplifier or so, and see whether there is sound output comes through the outer source or not. If there is sound from the amp; and no sound output from the TV, check the speaker first. If it is OK, replace the audiou output IC. If there is no sound through outer amplifier, the audio detectcion section inside your TV is faulty. You must have a thorough knoledge and skill to repair it. OK.
May 23, 2011 | Vizio VA22LFHDTV10T LCD TV
Why are the speakers not working? The volume button works.
First You need to check if the cable that is connecting Your device o any outer source is properly connected, once that is confirmed, then You know the problem is that the sound IC of the television is bad and need to be replaced.
To replace the sound IC, You need to get a cup, a screwdriver and a replacement sound IC, before You get a replacement sound IC, I will strongly advice You disassemble the television first to be able to tell the kind of sound IC You should buy. Follow these steps below to replace the sound IC:
  1. Turn of Your television,
  2. Disconnect it from the power outlet and allow it rest for about 6 hours, so the high voltage on it will dissipate,
  3. Then You unscrew the television open,
  4. Trace the wires that is at the back of the speakers, it will lead You straight to the sound IC,
  5. Disconnect the sound IC and get a replacement for it,
  6. Fix in the new sound IC,
  7. Reverse the steps to reassemble the television back together,
  8. Plug the television back and turn it on,
This time the sound will work perfectly fine.
Hope this helped. Thank You for using FixYa!!!
Jan 16, 2011 | Polaroid Televison & Video
No sound/audio while playing tv.
Hello
If there is no audio output from your tv, either your TVs speaker or its audio output IC has damaged. You just check it with an earphone/headphone, if there is an earphone or headphone socket in front panel of your TV. If there is sound from the headphone/earphone, and not from the speaker, means the speaker has damaged. You have to replace it with same type and number. Just check your set's audio out socket, if any provided, connet it to any external audio sourse, like amplifier or so, and check whether there is sound output from it. If not, your Tv/combos' sound processing IC inside has some trouble.
most common fault is related to sound output IC or speaker itself. If speaker is found OK, go to the sound output section. This section can be easly located as speaker wire goes to that section, and follow it. Before replacing the IC, check its leads for any loose or bad soldering. i advice you to resolder all the terminals of that IC, by applying a little more solder, without making any solder bridge loose contacts between them. If this does not helps, replace the IC with an identical type and number. OK.
Dec 24, 2010 | Panasonic PVQ-M2509 Combo
Sometimes when changing channels the audio will become static and will stay static for 2-3 minutes then the TV will turn itself off and back on again restoring the sound..quite annoying
once electronic devices start to develop faults, they tend to be quite annoying. But once you can have it solved, then you are happy and feel relaxed once again.
The problem mainly is from the sound IC, it is having some problems, it might be experiencing some kind of partial contact therefore having a kind of break in its main function.
What you have to do is to replace the sound IC of the television and you will not experience the problem anymore.
TAKE CARE
Oct 10, 2010 | Philips Televison & Video
I cannot get the sound on. We have the Model #80PP9753/17. Please advise. spilman@wbhsi.net
you cannot get sound from your TV because the sound IC is bad.
Unless you replace the sound IC, you will not hear any sound from your TV.
I would advice you take the TV to a local repairer within your vicinity so the the fault can be fixed.
Good luck.
Apr 12, 2010 | Televison & Video
I can not hear any Audio
the sound IC is bad, that' why you cannot hear any audio from your TV.
You need to change the sound IC to hear audio from your TV again.
Good luck
Mar 05, 2010 | Haier HTF24R21 24" TV
Intel 845GVSR Motherboard no display Problem
no diplay in this board give me sme notes to chag ic.what ic i did change
Jan 23, 2009 | Intel Motherboard
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
