Question about Microsoft Xbox 360 White Console
Disc is not reading - Microsoft Xbox 360 White Console
    Scholar:
  • 113 Answers
If your Xbox 360 console is not reading disc, first check it this happen to multiple CD. Check if the disc has scratches on it. If not, clean the disc by wiping it with damp soft cloth from the center outward. (Note: Use distilled water). Also make sure that the disc that your playing is compatible with your console. Next step is to clear the cache by going to My Xbox > System settings > Memory > highlight the storage device and Press Y on your controller > Select Clear System Cache. Then try to play again the disc. If still same thing, disconnect the hard drive, memory units and controllers and then reconnect it again. Try to play again the disc. If the problem only occur in one disc, replace the disc. If this happens intermittently, you need to contact Xbox Support for the repair of your console.
If your console is still under warranty, I strongly suggest that you call them to have free repair. Here's their contact number (800) 4MY-XBOX or (800) 469-9269.
Posted on Apr 02, 2011
Dvd player reads "no disc" when I put disc in
Are the discs copy's or originals if there copy's some systems will not read them, if there originals then clean disc on laser eye with a cleaner disc
Mar 07, 2014 | Sony BDP-S350 Blu-ray Disc / DVD Player,...
Disc inserted but NO DISK message appears
Try other discs to see if its still working properly...most likely the recording on the disc is not burnt properly or there's something wrong with the disc, (ie, scratched or surface dirt etc) or the DVD player just can't read the disc...for example can it read the type of disc(does it read dvd+r or dvd-r, or both?--- if i remember rightly)..... I've had discs that have had bad recordings but can still be read if placed into tray a particular way around... randomly try different positions, also cleaning disc as you go...depending on how desperately you want it to read the disc...could also be bad disc batch... there could be many reasons...
Sep 22, 2012 | Televison & Video
Getting disc read error
THere are a number of problems that can cause a disc read error. The lens can be damaged or very dirty. The motor that moves the les could be stuck or damaged. The disc could be dirty or scratched. Or the disc format might not be able to be read by the player. Do you try more than one disc? Are you trying different types of discs? like store boght discs and recordable discs. Some players wont read mp3 or cd-rw discs.
Jun 20, 2010 | Alpine CDA-7894 CD Player
No disc
has it been reading discs previously? If it has been reading discs previously, then it means the lens (laser) of your player is weak and that's why it cannot read disc.
You need to change the lens for it to be able to read disc again.
Good luck.
Apr 15, 2010 | Panasonic DMP-BD30K Blu-Ray Player
Mariokart disc could not be read. manual said
Did it ever work? Or did you just get the disc?
If the game never worked, you may have gotten a defective game disc. Take it back to where you purchased it and they will exchange it.
Nov 11, 2009 | Nintendo Mario Kart (Wii) for Wii
Wii can"t read disc
If Wii gives can't read disc, so first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 14, 2008 | Nintendo Wii Console
How to download unreadable disc for lexmark printer
The printer install disc may be faulty or your disc drive is faulty.
Insert the disc into a different computer, if it can be read then the problem is your disc drive.
If it is your disc drive, turn off your computer, open your computer and remove and reconnect the power and data cables on the "faulty" drive, switch on your computer, let it boot up and install the printer disc.
If it still cannot read the disc then you need to replace the faulty disc drive with a new one.
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Unable to read wii discs
I had the same problem, I take it you have a modded wii(chipped), if you use a backup disc it is of a lower quality then original discs, the wii gets read errors without you noticing and tries to read those disc areas again sometimes suceeding and the gaming goes on, sometimes it fails, and a disc read error occurs. Over time the dvd assembly will take some damage it will loose it rigidity it once had and the wii stops reading discs. The problem gets worse if you have standing up, so first thing si to flip it down and try. Otherwise you (or someone you trust) will have to open the wii and adjust the lens sled so it wont flap as much up and down. Hope this helps..
Oct 01, 2007 | Nintendo Wii Console
Microsoft Xbox 360 White Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
