Model:Brother DCP 135C Clean Unable 46. Kindly please help me to solve the problem.Tq.
Troubleshooting and routine maintenace
Posted on Jun 19, 2011
  • 1,218 Answers
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Get more help and information click here. hope this helps you.
Posted on Apr 04, 2011
  • 794 Answers
Hi cptnah,
The error message CLEAN UNABLE 46 means that the waste pads are needed to be replaced because these are already saturated with ink. Here's the instruction how to replace your Pads:
1. For the Upper set of Pads, you need to take the scanner assembly off. At the back you'll see the upper cover, control panel and the flushing box.
2. The second pad, you need to take out the printer mechanism and platen roller, the bottom plate and the print head.
Once you're done replacing the pads you need to reset the system. Replacing the waste pads will help you resolve the issue.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 02, 2011
"clean unable 46 " and see troubleshooting and routine maintenance chapter in users guide.
HI Gail,
Please watch this brother problem related video and solve your problem.
Still having Problem Then follow Us For Brother Printer Support
Mar 22, 2014 | Brother DCP 165C Compact Color Inkjet...
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
Unable to clean error 46 Printer Brother DCP-6690cw
my DCP 6690 printer causes problem unable to clean 46 how can i solved this ..............
Jun 12, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
PROBLEM IS MY PRINTER SHOW ERROR CLEAN UNABLE 46
Hi
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
DCP-135C after inserting new inks message reads "Maintenance and users guide chapter 46 cannot clean" Will not print.
Dec 01, 2010 | Brother Office Equipment & Supplies
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean unable 46
46 says the ink absorber box and flushing box are full, you need a shop to replace these and reset the counters. It's possible to just reset the error but you risk printer damage if they overflow.
Feb 01, 2010 | Brother DCP-135C Flatbed Digital MFC...
UNABLE TO INSTALL MY BROTHER DCP-135C PRINTER/COPIER
Hi!
Please open this link and select the model no. of your printer from there and then it will open up a new window from where you have to choose the drivers you want to install.
Link For drivers.
Do rate the solution
Thanks
Rylee
Feb 09, 2009 | Brother MultiFunction Center MFC-440CN...
Unable to clean 46
posted fix in another prob same section
Aug 23, 2008 | Brother DCP 130C All-In-One InkJet Printer
1,075 people viewed this question
k24674
