Have error code E2 for my washing machine WF F781 TC.It is just over 12 months old and iss super slow to wash it stops in middle of cycle. have electrician here now but do not wa.t to let him touch the machine till we at least find out what E2 IS. I HAVE LOST THE MANUEL. Please help now
ap1960
SOURCE: HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Posted on Jul 08, 2007
  • 1294 Answers
SOURCE: WF860 error code
Click on your model numbers (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. You might find the mysterious codes there.
And dont forget to rate me on this great site.
Posted on Jan 17, 2008
  • 3 Answers
SOURCE: aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Posted on Dec 28, 2008
jsrock516
  • 5911 Answers
SOURCE: washing machine blinking f-24 error code.
"F24" is a Water Temperature Sensor error or Heating Circuit failure. The first step to troubleshooting these washers is to unplug the unit for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes the error codes can be erroneous and a simple reset of the CCU will correct the problem. If the error code reappears following a CCU reset, you have a genuine problem.
If the error code comes back, check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Check to make sure the connector is still plugged in. The connector can become loose or unplugged due to vibration. If the connector appears to be okay, unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
I hope you find this information helpful. If you have further questions, please let me know.
Posted on Apr 12, 2009
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
Simpson 8.5 kg Eziset stops after wash cycle with error message E20. Am pensioner and unable to move machine. Machine is approx 4 months old. an you assist with advice pls.
If it's only 4 months old it should still be under warranty. Contact the place you bought it from and explain your problem to them. They should repair it at no cost.
Sep 17, 2014 | Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Whirlpool washer f3 e2 code
your main control board is having a problem need to have service rereplace it free of charge and the board has been upgraded
Sep 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Lg Fuzzy Logic 5.5kg Turbo Drum with I-sensor, Model WF-T552TH Washing machine goes through initial fill up, when changing to spin/wash works for 2 seconds, then stops spinning back and forth and shows dE...
There is a small magnet at the front of the lid that triggers the door error, mine was corroded and the lg people wanted $80 for a service fee.. Ha I went to my local hobby shop and got a small earth magnet and some super glue $1.50 later and she's fixed.. tadAaa.
May 11, 2011 | Washing Machines
My 6-month old topload WF 8702CPG keeps stopping in the middle of the cycle with the code LE. Going crazy tyring to figure out what's wrong. Error code not in the manual. What does it mean and how do I...
this means the lid safetey switch is a bit out of adjustment LE means Lid Error. if you press down on th lid it might take the error away while you are pressing. without breaking the lid. This will prove the lid error. A warranty call may be necessary . 6 months old must be under warranty Good Luck
Sep 11, 2010 | Washing Machines
Wash Cycle doesn't start
Unplug the machine for about fifteen minutes. When your fuse blown it caught in the middle of the cycle. By unpluging it will reset the machine.
Dec 07, 2009 | Washing Machines
Shows OE error. Won't spin
if its only 6ths old call out the manufactures.
Sep 28, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
