Question about Miele Washing Machines
Washing machine won't drain - Miele Washing Machines
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Hi, youve probably sorted the the problem by now but after talking to a miele engineer, he told me the main problem with blockages is caused by not using the very hot cycle enough, although the pipes and filters seem clean, there are still deposits in the drum and various other parts and washing at 60 deg wont shift them.
my machine wasnt draining properly either so i was told to do a 95 deg wash with no clothes in just biological powder,( i added dishwasher powder too!)
the colour of the water was unbelievable!, i ran 2 cycles with soap in at 95 deg, then one with just water, flushed out the drainage pipe(wich was full of whatever **** that came out of the machine), its now washing like a new machine, whites are certainly whiter, and have been advised to do a very hot wash every 4 or 5 months to keep things clean
hope this helps
Posted on Nov 29, 2011
  • 2,510 Answers
Check the inlet to the pump for blockage, make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe. Check the filter to see if it is not clogged or obstructed. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Posted on Apr 02, 2011
Asko 620 washer won't drain well with heavy load
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | General Electric WBVH5300KW Washer
Water will not drain out of the washing machine and won't complete cycle.
heatman101
Sep 10, 2011 | Kenmore Washing Machines
Washing machine won't rinse and the water won't drain out.
heatman101
Sep 04, 2011 | Washing Machines
Whirlpool washer model LSR5232LQ0 won't drain. just stops. is there way to cause drain?
heatman101
Aug 22, 2011 | Whirlpool Washing Machines
Washer will wash but won't spin or drain
heatman101
Aug 11, 2011 | Kenmore 22422 Top Load Washer
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
Washer won't drain
heatman101
May 23, 2011 | Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
heatman101
May 14, 2011 | Frigidaire Washing Machines
Washing Machines Logo
134 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
