Question about RCA HDLP50W151 50" Rear Projection HDTV
Capacitors Thanks, but I read that post yesterday and I replace dall four of them. Same symptom. Maybe I need the whole board. What do you think?
  • RCA Master
  • 8,617 Answers
Does your set blink 5 tinmes?
Posted on Aug 05, 2008
Samsung PN50C590G4F plasma TV turning on and then off with clicking sound after 6 seconds
Have you tried replacing the power cord or the voltage feed may be off replacing the whole cord should correct that
Jan 02, 2015 | Samsung PN50C590 TV
Four red blinking lights came on and I mistakenly thought it was the Lamp. Read further that it could be the fans whereupon I cleaned both rear fans thoroughly but neither fan came on. Now I have two good...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout in rectifying the problem....
Jun 09, 2011 | Televison & Video
I have an element TV with a MLT070A power supply board. I'm not an electrical guy, but a technician came out and showed me the bulged caps and said that was what's wrong with the TV. He said he...
power supply board is dead, if you know basic electronics' and soldering you can handle it ? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.
Good luck in solving the problem.....
May 17, 2011 | Televison & Video
When I press the power button on my 42MF521D/37 Magnavox LCD, the green power button flashes but it never turns on. I have also noticed that the backlight on the screen flashes too. I have pulled the power...
This problems the power supply board still have more parts are dead,than just those capacitors are noticeable are dying leakages capacitors are bulging ups.U must have more electronic skills and equipments like a Scope to check those transformers input and output reading and a Capacitors reader tester to icesolate to check for more of those capacitors u think are good,but they have short in it,give out less micro feret and voltages as they should to the power supply board.Tries wesite like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 31, 2011 | Philips Magnavox 42MF521D/37 Television
Takes to long for it to turn on. Think the switch is going bad.
I believe your problem is going to be defective filter capacitors in power supply. Classic symptom of taking longer and longer to come on. Will get progressively worse over time then wont come on at all. No need to replace the whole power supply board. Most knowledgeable repair shops will replace the swollen capacitors or you can try yourself if you are familiar with electronics.
The defective capacitors will usually swell up out the top making them easy to spot
Oct 17, 2010 | Samsung LA40A450 40 in. LCD TV
I have a 2005 toshiba 56hm195 with thin lines running through it
if retrace on screen maybe the capacitor is running defective.on the screen. consult that problem to Toshiba service center.
Jun 20, 2010 | Toshiba 56HM195 56" Projection HDTV
Where can I buy a power supply for an AOC LCD monitor model TFT 1780?
hi, i don't know if you will ever find just the power supply board for this monitor. i repair lcd monitors for a side business and i have never found the exact power board i needed for any of the monitors except for dell 17in. you would have to look on ebay for another broken monitor just like your with a working power board, broken screen maybe. that being said, why do you think you need a power board complete? the parts on the board are replaceable. maybe you could post a reply so i can read to help with what the symptoms are and help you diagnose the problem components? if you posted pictures in your reply of both sides of the board, it might help me describe more in depth.
Mar 08, 2010 | AOC 1780 (Beige) 17 in. Flat Panel LCD...
Tv no picture Akai
I don't remember exactly which ones I replaced.Look at the capacitors on the power board,and replace any that have the top,or bottom bulged out.The capacitors didn't cost much,maybe around $10 with shipping,depending on how many you need.Do you have your power board out?I hope this helps.If you have any questions,please let me know.
Thank You very much!
Tyler
Oct 27, 2008 | Akai LCT2785TA 27 in. LCD Television
Green blinking light problem too. on a Mitsubishi WS65869
You can go to this link they have the kits with the high temp higher volt capacitors and complete detailed instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jun 03, 2008 | Mitsubishi WS-55909 55" Rear Projection...
RCA HDLP50W151 50" Rear Projection HDTV Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
