E38 - Washing Machines
  • 17,970 Answers
Unplug the appliance and take the top off.
Locate the pressure switch and take the thin tube off of it. (There may be two pressure switches, if there is, take both tubes off, block one with your thumb).
Blow as hard as you can down the tube to try and clear any restriction.
Refit the tube(s) and try the machine again.
If it works, you'll need to run some maintenance washes (boil washes without detergent or clothes) to try and disolve the build up of gunk and undisolved soap.
Look for the thin tubes that attach to the pressure switches, you may have 1 or 2 of them on your appliance. They are at the top, possibly on the right hand side although different factories put them in different places.
Just disconnect the tubes at the pressure switch ends, then blow down into the tube and pressure chamber.
Don't forget, disconnect both tubes, block one with your thumb and blow down the other.
Posted on Apr 02, 2011
E38 error code
Hi Friend, thank you for allowing me to assist you!
Typically an error code E38 on your Frigidaire washer could mean a few things:
First see if the air trap is clogged. If it is, that is probably the most likely issue.
If it is not clogged, it could either be the main control board, the water valve assembly or the pressure sensor switch.
To make sure it is not a false error code, reset the power to your appliance by either unplugging it or flipping off the breaker for about 30 seconds.
If the error code continues to display, I would strongly recommend contacting a professional to make the necessary repairs. Unfortunately, most electronic parts cannot be returned so it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Best regards! - Z
Jul 20, 2014 | Frigidaire Washing Machines
I have a Frigidaire Affinity front load washer Model ATF7000ES0 and am getting error code E38
Hi Scott Brown: Typically an error code E38 could mean a few things:
· First see if the air trap is clogged. If it is, that is probably the most likely issue.
· If it is not clogged, it could either be the main control board, the water valve assembly or the pressure sensor switch.
· To make sure it is not a false error code, reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds.
Apr 15, 2013 | Frigidaire Affinity ATF7000E Front Load...
92 cadillac engine codes e13, e38, e44
HESE ARE OXYGEN SESOR CODES REPLACE THE OXYGEN SENSORS AND CHECK THE CONNECTORS
Nov 07, 2009 | 1992 Cadillac DeVille
Can anyone tell me how to replace my dashboard lights on my bmw 316i compact?is it a big job?
Visit e38.org as a starting point just to have an idea. It shouldn't be a major job.
Sep 19, 2009 | Car Audio & Video
Oil rear diff
80-90 grade from a well nown oil company
my self i would put the synthetic version for ultime
protection
Apr 19, 2009 | 1998 BMW 7 Series
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
