Question about Lexmark X1270 All-In-One InkJet Printer
MY PRINTER WILL PRINT TEST PAGE AND DOCUMENTS, BUT IT WILL NOT PRINT ENVELOPES, AND YES ALL THE SETING ARE SET FOR ENVELOPES, AND I HAVE THE DISK AND TRYED TO REINSTALL THE DRIVERS,,DID NOT WORK
  • 1,031 Answers
Check the setting configuration for envelope the problem should be from the configuration for envelope may be its not properly confirgured
Posted on Aug 05, 2008
How do I print envelopes on Brother MFC6490CW
Load the envelopes in like paper, tell the printer the size of these to set the paper size, then whatever you're using to print on the envelopes, set up the page size the same size as the envelopes. You should then be able to print on envelopes
Oct 07, 2014 | Brother MFC Office Equipment & Supplies
I have a brand new ink cartridge in my printer. It printed the test page ok. When I try to print envelopes, it always says paper jam (there is no paper jam) the envelopes just wont feed. It's a Lexmark...
Make sure to set the correct paper setting on the printer or the Lexmark software before sending the print job. Adjust the printer's paper guide to the correct envelope dimension.
Dec 12, 2011 | Lexmark X6170 All-In-One InkJet Printer
You mus set the printer for envolopes, Also set it under print preview on your word, or whatever program you are printing from. also make sure your auto document feeder is set for envolope. The stock in the pritner for the same. Hope this is of some help if the issue persist let me know
Dec 12, 2011 | Office Equipment & Supplies
Does this printer print envelopes
Information and drivers for your printer can be found here:
http://www.ricoh-support.com/enduser/downloads/advsearchresult.asp?type=main
Beginning on page 33 of the PDF of the Hardware Guide there is a description of the paper types that can be printed.
Yes this printer can print envelopes. On page 37 of the PDF there is a description of how to load and print envelopes.
Trust this is helpful. Please vote.
Dec 18, 2010 | Ricoh AficioSP C221N Laser Printer
Need to pring envelopes on my konica Minolta hub 350 printer
Place envelopes in either drawer 1 (top drawer) or the by-pass tray. Generally, the envelope is placed side to be printed down. (On the printer you can set up custom envelope sizes.)
Select Print. Click 'Properties' for the printer. In the resultant dialogue window, set the printer to print to the 'envelope' print path.
Click OK, click Print. (test print direction first)
Check your printed envelope. You may need to change the orientation of the envelopes to print with the opening at the top.
Jul 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do I print envelopes?
Your printer has a set up program already in the system. Go to Print; when the page comes up, set attributes for envelopes on the printer.
Apr 29, 2010 | Dell 3100cn Laser Printer
We have an officejet 8500 premier, we did not get a manual with it, how do you set the printer to print envelopes from the bottom tray? We print a lot of single envelopes, and have to take the paper out of...
go to the printer folder and do a right click on the printer icon and select printing preferences and in the printing preferences page you will get the option to print envelopes and i think it is the best way to print envelopes ............................try this out .......................thank you
Oct 16, 2009 | HP Office Equipment & Supplies
HP Laserjet 1100 - prints test page text & image on envelopes
try to uninstall the drivers and reinstall them it should fix it
Jul 20, 2009 | HP LaserJet 1100 Printer
LEXMARK X1240 WON'T PRINT ENVELOPES
I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
Jun 01, 2009 | Office Equipment & Supplies
Can the Epson Stylus Photo R1800 print on envelopes?
yes all sizes of envelopes using Microsoft word i have printed on 100mm square paper but only documents
Feb 20, 2009 | Epson Stylus Photo R1800 InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
