Question about SAMTRON 55V 15" CRT Monitor
Samtron 45bn monitor and the chassis no is bh41-000527a da14/15L. problem is IRF630(Q504) is short.i changed new one again it get short.i switched on the monitor power on for 2 secns then it gets off.Q504 is short again.HOT is OK i removed LOT and tested still same result.i tested Q502,Q503 all OK.i changed STV7779.still same result.(Q504 short frequently) 12v ok,instead of 53 v Q504 receives 69 v. help me plsss
MicrowaveSvc
  • 9047 Answers
SOURCE: Samtron 94v 19nch problem helpppppppppppppppppppppppppppppp
If it's still under warranty I would call for repair service. It sounds like typical internal power supply trouble that needs electrical troubleshooting.
Posted on Jan 12, 2007
SOURCE: Monitor loses resolution
retres line in pictur
Posted on May 24, 2008
shaggyrat
  • 1224 Answers
SOURCE: problem with the samtron 45bn monitor
sounds like your video card went out simple check of this
if you have another computer that works hook it up to its computer if screen comes on it will be your video card in the comp now if the screen still doesnt work it will be the cable the pins in the end has some how bent or come loose this will require a service tech electrician to repair simple quick job
Posted on May 26, 2008
SOURCE: samtron 45bn problem
HI I AM SAMTRON 45BN COUSTUMER
MY PROBLAM IS MY MONITOR HAVE ON AND FEW MINUTE LED GLOW AND AUTOMATIC OFF
Posted on Dec 15, 2008
AndystUK
  • 131 Answers
SOURCE: To open the Samton 45Bn crt monitor
turn off power.
Get a long philips screw driver and remove the base and all fixing screws. some are hidden behind blanking plates and the com off with a sharp knife and a getle lifting at the join.
After all screws are removed the lie the screen downwards and start to pull away the backing.
you should get the case apart easily.
You must be aware of the tube holding a full charge at its end. DO NOT touch this at any point. The only thing you should try to inspect is the fuse or adjustment to the focus slant contrast etc.
AndystUK
Posted on Aug 30, 2009
Problem in Samtron 45Bn Monitor
Try connecting the monitor to the mains instead of the UPS.
If it works OK then the problem maybe the UPS and that it is very close to the max output of the UPS.
If not then the monitor is faulty.
Mar 12, 2013 | Computers & Internet
When I switch on my computer, Windows XP start loading and then my Samsung Samtron 45Bn monitor's screen goes blank and the green light keeps flashing every 0.5 secs.
It sounds like your video is set to the wrong resolution. Try booting into safe mode by pressing F12 at the start of the boot process. If you get into windows that way, then adjust the display to something you monitor can display like 1024x728@32bits. The monitor can only display a certain amount of pixels and if you set the video card to high you will lose visual. Hope this helps.
Mar 19, 2011 | SAMTRON 55V 15" CRT Monitor
Samtron 45bn power regular on/off
just replace the FBT FEA830 and check
Feb 11, 2009 | SAMTRON 55V 15" CRT Monitor
BLINKING OF SCREEN
check for Dry Soulders & FBT....
Jan 06, 2009 | SAMTRON 55V 15" CRT Monitor
EHT PROBLAM
EHT Problemsymptems :1.If U find R457 - 33k,R452 -1k,R458 - 10k Resisters are Burnt In Zenith 14"and15" monitors To replaced all thease resisters and LOT FSN14B016S
2.HCL HCM 482M, 580M,582M, 780M models getting FAT - FAT sound coms from LOT when u switch on the monitor It's LOT Problem . replaced it
3.Samtron Samsung Models like 45Bn, 55V,56V when u switched on the monitor Power indicator (Led )glow one time First u can check Boosting FET IRF630 bitween (SMPS O/P to LOT supply) and also replace LOT.
4.some Old Gold star anlog and LG monitors If U found 12k Resister near by LOT and also bulched 1Mfd/63V capacitor
It's LOT Problem
Oct 04, 2008 | Computers & Internet
Samsung (samtron 5Ei ) rebooting & EMI problem at times it is O.K.
Check 5 v at 7805 output and change Memory IC (EEPROM).
Check SMPS o/p voltages
Sep 20, 2008 | SAMTRON 55V 15" CRT Monitor
Problem with the samtron 45bn monitor
May 25, 2008 | Computers & Internet
Samsung 45bn
hi... there's a resolution problm with samtron45Bn with win xp.
Pl.help to fix this pblm.
May 22, 2008 | Computers & Internet
SAMTRON 55V 15" CRT Monitor Logo
83 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Richard Lilja
Richard Lilja
Ted Maxwell
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
