Question about Daewoo FR640K
Daewoo no frost quite old keeps on turning the motor on and off all the time
  • 126 Answers
This is what they call cycling u need to have a tech come look that it,it is either low on freon or the timer for the defrost has gone out
Posted on Apr 02, 2011
I have a side by side whirlpool fridge and the freezer is fine but the fridge is now freezing everything. It's about 11 years old.
Since you stand to loose all the food I would call a service tech ASAP. But here are the most common reasons for the problem you have.
Cause 1
The Evaporator Coils are Frosted Over The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Nov 19, 2016 | Whirlpool Refrigerators
How to identify why my Daewoo ERF-364MNL fridge freezer is warm
This is a fairly common problem with most Frost free Fridge freezers. The system relies on regular automatic defrosting, and if there is a fault in that, the cooling cycle is seriously affected.
The problem could be as simple as a blocked defrost water drain tube, or more complicated such as a failed de-frost heater, defrost timer, or drain tray heater.
To check and repair any of them, is quite an involved process which involves stripping a lot of trim, and other parts just to get to them.
I would suggest that you get a qualified Refrigeration Engineer to repair it.
I hope this helps?
Feb 08, 2016 | Daewoo Refrigerators
Doewoo no frost fridge freezer is working fine except that we keep getting puddles of water under the freezer door. any ideas. had about 4 years now
probably a blocked drain outlet or pipe. At the bottom rear of the unit, mine had a drain pipe blocked with a plug of mould (5/6 years old machine), apparently quite common. I detached the pipe and cleaned it out and replaced it.
From inside the freezer, I removed the lower back panel and thawed the ice build up on the drainage tray below the defrost heating element, leading to the pipe outside. The puddles of water that was appearing every defrost cycle have now stopped - permanently I hope. Hope this helps you
Sep 02, 2012 | Daewoo Refrigerators
Model FRS-U201A fridge freezer and fridge is not keeping cool, only 3 years old, ssems to have occured in a couple of days
look on back wall of freezer if there is frost build up you have a defrost problem can be defrost heater defrost control board or bi-metal is open and not tuning heater on if no frost you may have low freon problem this can cost check first part of this post 90 % of the time its a defrost issue
Aug 18, 2011 | Daewoo FRSU20IA Freezer
How to replace a broken timing belt for a 1998 daewoo lanos?? Would there be any head damage?
yes it is quite possible that valves are bent if the cam belt broke or teeth stripped off of old belt, which unfortuneately means removing the cylinder head and getting it repaired (valves replaced and possibly guides) see some of my other posts for cam belt timming marks locations etc...
depending what motor is in your vehicle twin cam or single?
stevenhurc_14.jpg and if its twin cam you usually need cam locking tool for cam gears.
Apr 20, 2011 | Daewoo Lanos Cars & Trucks
Have a Dawoo no frost fridge. It is getting ice in the bottom of the freezer compartment, and it is dripping water, not into the drip pan in the back, but rather out of the front on to the floor. Otherwise...
You might have to pick a time to switch off your fridge all together for a half day and defrost it and the turn it back on it will probably be ok after that make sure the fans are working properly etc a no frost fridge usually has a heater that comes into play thats why no frost so to speak . but turn it off (plan the best time ) and make sure its fully defrosted . switch it back on and you should be go to go .
Oct 26, 2017 | Daewoo FR143 Compact Refrigerator
Daewoo Fridge Freezer not getting cold
Possible problems are a bad evaporator fan motor or a defrost problem. If the back panel in the freezer is frosted up then it is a defrost problem. If no frost listen for the fan in the freezer. If you don't hear it then it may be the problem. Not circulating the cold air.
Oct 04, 2007 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Daewoo FR640K Logo
239 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
